Author Topic: shed cleanout  (Read 2310 times)
shed cleanout
« on: October 31, 2011, 12:35:11 pm »
too many projects on so some gear has to go coz ill never have time to do some of them!!
cr250rz complete motor  needs new rod,bearings,seals and barrel rechroming and has been ported,come with full gaskit kit $400 or a good offer
cr250 81 on new inlet manifold 16227 ks7 830 $20
cr250 rz carb has been cleaned and polished $85
cr250 83 cdi box $70
cr250 78 to 80 atc25081 to 84 wisco .25 piston kit minus p/pin $80
fl250 oddy fuel pump $20
xl250rh cdi box $20
clear float bowl to suit 36/38mm mikuni $10yam ag175 new fuel tank cap $10
tt600/it series speedo bracket,needs slight panel beating $10
ts185 all including er's 2mm wisco piston no p/pin $60
xl/atc185 .75mm complete piston kit $50
yam mx/yz400 all .25 piston$35
mx/yz400 all std rings $10
it175g maybe bigger it's plastic speedo bracket $20
xt600 tacho with wiring loom $30
tt600 6v stator done only 4000kays with wiring $5o
tt600 complete rear axle $20
and more to come
open to good offers on all parts
0451504849 after 3pm
Offline frostype400
Re: shed cleanout
« Reply #1 on: October 31, 2011, 12:46:42 pm »
Hey Matt, I would like the clear float bowl to suit mikuni I'll add it to the money I am sending you, thanks Michael. :)
1971 tm400 and PE's
Re: shed cleanout
« Reply #2 on: October 31, 2011, 01:11:33 pm »
If you find another clear float bowl please put my name on it since i missed this one.
Re: shed cleanout
« Reply #3 on: October 31, 2011, 03:09:51 pm »
sorry Leith ive only got one and had it for 25 years at least
Re: shed cleanout
« Reply #4 on: October 31, 2011, 03:32:50 pm »
I bought one off Marks Swapmeet a month or two ago. Looks like you've missed two Leith ;D
