Author Topic: DR500 GURU/BRISBANE  (Read 12834 times)
Offline EML
DR500 GURU/BRISBANE
« on: October 19, 2011, 03:22:21 pm »
I'm looking or a DR500/600/700 guru in Brisvagas. Someone that can breath some fire into it and not steal all my pennies.
Offline mick25
  • Hunter valley NSW
Re: DR500 GURU/BRISBANE
« Reply #1 on: October 19, 2011, 04:41:25 pm »
I would keep clear of fire breathing the dr500, I have raced one for the last six years
when i got it, it had a broken gear dog
So i did a full gear box rebuild.
 last saturday I dumped the oil and the new gear is broken again a broken dog siting in the sump
I have a spare gear box in bits ,and that has the same one broken as well :'(
Its the 4th gear on the sprocket shalf it runs 2nd and third as well, it has  three small dogs on each side of the gear.
The other gears have four dogs on each side or 3 larger ones than the weak one above.
Its a shame they go well ,
Im not sure how much it will cost to get a gear made stronger there is room for bigger dogs on it....
« Reply #2 on: October 19, 2011, 04:43:26 pm »
Litres Of fuel and a match should solve all your problems  ;)
I take it you have removed the counter weights  etc
Pistons Std = 88mm x 20 pin - so you can use  XT/TT/SR 500  1mm over = 89mm
 but will need to do a bit of work on top of piston as DR 500 are 4 valve.
Honda Xr 500 are 21 Dia pin so are are no good to us.
Offline EML
« Reply #3 on: October 19, 2011, 05:01:11 pm »
which fuel Oldfart-premium unleaded or methanol, and will a bic lighter do the job or some BBQ matches???
I don't recall ever having gearbox issuses back in the day with Geoff Udy but hay, I was just the nut on the side.
There was talk that one guy ran a 700 then too and Walducks Suzuki in Townsville ran some at the speedway that were way quick in midget cars.
Offline mick25
  • Hunter valley NSW
« Reply #4 on: October 19, 2011, 05:04:27 pm »
You can work the top end of the DR500 buy the sounds of it ,
With larger pistons..
but will break the gears for sure,
 I have three broken ones to prove it and im easy on gear boxes because i dont like rebuilding them.
My two DR500s run stock pistons ,but I run 38mm flat slides and bigger dia header pipes etc etc.
I did think of removing the counter weights but was conviced buy a bike machanic to leave them there .
The counter balance weighed around 3kg to 4kg all the cogs chain etc.
So its a fair bit of weight saving on the heavy girls.
I have TT500s as well there gear dogs are twice the size and I have never broken one in 20 years. 8)
Offline mick25
  • Hunter valley NSW
« Reply #5 on: October 19, 2011, 05:15:39 pm »
All the broken gears i Have..
They Have only had only one broken dog missing out of the three on it
so it still works, you cant realy notice it missing when going through the gears .
But its in the back of your head if the others go or not.
I do race starts in 2nd gear what runs of 4th gear what is the weakest link.
So its a bit of a worry
thats my take on it
Offline EML
« Reply #6 on: October 19, 2011, 05:33:43 pm »
thanks mick, it all helps.
Offline DR500
« Reply #7 on: October 19, 2011, 07:41:57 pm »
i have removed my balance shafts and it makes them rev quicker.I have never had any problems with my gearbox and i do give the old girl a hard time.I have fitted a dr600 flat slide carby which is a great improvement.The only work i did to head was clean up the ports and match manifolds.Hope that's some help.
Offline QLD779
« Reply #8 on: October 20, 2011, 08:49:02 am »
Hey EML. You remember the DR outfit we had. Wiesco piston, Ivan Tighe cam, (they might still have the specs) and the bit that made the bigest difference was installing a Amal carb. Never had a gearbox issue.
You don't have to be, but it helps.
Offline EML
« Reply #9 on: October 20, 2011, 09:17:50 am »
JEEZ Dave, still looks fast just sittin' there. Ask Max what size it actually was pls.
Offline QLD779
« Reply #10 on: October 20, 2011, 11:30:06 am »
I'll ask, but Max didn't build the engine. Try asking jeff as we had exactly the same piston. ;D
« Reply #11 on: October 20, 2011, 01:02:10 pm »
i think gear breakages also depend on riding style. I still hear of people flat shifting ::) XR/XL500/600 & TT/XT600 were all known to break gears with sidecars too. Everyone that one one knew it and was aware of it but it was just part of racing but it was not like a gear broke every event. It was never as big a deal as people made it out to be and everyone just had supplies of spare gears. If you started with a full set of very good gears that was a big help.
« Last Edit: October 20, 2011, 01:04:51 pm by LWC82PE »
Offline EML
« Reply #12 on: October 20, 2011, 01:23:46 pm »
Thanks Leith, as I mentioned earlier, I don't recall Geoff ever having gear issues but I guess they were all new then.
Offline sudman
« Reply #13 on: October 20, 2011, 03:27:49 pm »
If you cryo the gears & fit a cush drive rear hub that should stop it, it's how we make the XL350 work as they like to blow the drive dogs off when you are making big hp.
Offline EML
« Reply #14 on: October 20, 2011, 03:44:36 pm »
Interesting thing about the cush drive, I have two rear hubs that came with the wreck I bought and another full wheel assy. They all have different size axles! They are all from DRs of different vintages and the complete wheel is cush and off a DR400 road trail. It has the biggest axle and wont go through my swing arm.??
Either way I'll be building new wheels up by the looks of it in any case.
