Author Topic: YZ 250 bars  (Read 3265 times)
Offline walshy
YZ 250 bars
« on: October 13, 2011, 07:22:04 pm »
Trying to find a set of bars for my 1979 YZ 250f. I am 6'3" and like to ride with my hands above my knees! Does anyone know of a brand that makes a high 22mm bar other than protaper and renthal.(tried them)
Cheers.
Offline holeshot buddy
  • sunshine coast qld
Re: YZ 250 bars
« Reply #1 on: October 13, 2011, 07:37:28 pm »
walshy turn some spare handlebar clamps upside down on top of triple and run long bolts
i use renthal kx high they seem good ;)
follow me to first turn
Re: YZ 250 bars
« Reply #2 on: October 13, 2011, 07:59:38 pm »
Jump out of a tree a few times until you become more normal-sized
ted
Re: YZ 250 bars
« Reply #3 on: October 13, 2011, 08:14:51 pm »
If i send you a set of bars that won`t fit will you drop a fifty and a bottlo voucher in the box when you return them....
You shouldn`t have done that you lunatic.....drinks are on me i guess ;)
Offline walshy
Re: YZ 250 bars
« Reply #4 on: October 13, 2011, 08:21:36 pm »
 You are welcome Ted!!
Offline walshy
Re: YZ 250 bars
« Reply #5 on: October 13, 2011, 08:23:29 pm »
P.S Mainline,
If you are normal then God help us!!
ted
Re: YZ 250 bars
« Reply #6 on: October 13, 2011, 08:37:08 pm »
Cheers.
Shoot Don a message..... >:(
Re: YZ 250 bars
« Reply #7 on: October 13, 2011, 10:10:02 pm »
Big part of the problem is the swept-bar bar mounts on the top triple, and the long forks that stop you using a top triple clamp with conventional mounts.
If you can work out a way to deal with the long forks, you could investigate something like YZ125K triples that have straight bar mounts. I couldn't believe the difference they made on my KDX.
Quad bike bars are popular if you really want a high bar.
Personally, I hate anything higher than Renthal 764s, because they make it very hard to get your weight forward, esp with the stock top triples.
Offline walshy
Re: YZ 250 bars
« Reply #8 on: October 15, 2011, 09:36:17 am »
Cheers Nathan.  Looks like I can use an "MX7" steel bar from msc. ( I think)
Re: YZ 250 bars
« Reply #9 on: October 15, 2011, 02:43:39 pm »
Be aware that a lot of the high-rise steel bars also have a lot of sweep - they jam your elbows into your rib cage and make it hard to steer. Presumably this is because they're designed for old style road bikes.
Offline number8
Re: YZ 250 bars
« Reply #10 on: October 16, 2011, 11:17:17 am »
I have a strait set of original bars of a YZ465 81 model they are black for a reasonable price,if you would like them.
#8
