Author Topic: maico ign  (Read 4762 times)
Offline holeshot buddy
  • sunshine coast qld
maico ign
« on: October 10, 2011, 08:03:53 pm »
just noticed in the uk they dont use pvl or any other ign on the 490
just a good motoplat and they start first kick :o
follow me to first turn
Re: maico ign
« Reply #1 on: October 10, 2011, 08:07:10 pm »
After persisting with a PVL and not getting good results i think the Motoplat is the way to go. The poms would know.. there's thousands of Maicos racing over there.
Offline KTMaico
  • "Love or Lust it's always a Maico"
    • Maico Lovers & Fans
Re: maico ign
« Reply #2 on: October 10, 2011, 08:46:45 pm »
Yes the PVL Ignition, must have, on all good Maico 490's, Junk the Motoplat!!  I fell for the rubbish and bought a PVL for My Maico 490 and I found what a lot of 490 owners now know, PVL's don't rotate fast enough to get a good spark when kick starting your bike. While the Motoplat gives a better spark and more voltage out when kick starting. I am told the PVL does work well on other makes of bikes that don't have the rotation limitations of the Maico 490. I will give my PVL one more go after I put in the 18mm decomp valve i got from the UK, it is supposed to let you crank the Maico 490 faster thus more voltage and spark.
Noel Harker has fitted the 18mm decomp on his Maico, I am not sure if Noel runs a PVL or Motorplat. For what it is worth the PVL would offer you a very light rotor compared to the Motoplat. I am a little bemused and a bit pissed off that no one has been 100% truthful in regards to the Maico 490 and the PVL combination. I just wished someone told me don't bother with a PVL on a Maico 490.
1981 Maico 490 (Special Build)
1979 Husqvarna CR250
1975 Suzuki RH250
1975 Suzuki RM125 S
1959 Mk1 Jaguar 3.4 4 speed manual with O/Drive
Re: maico ign
« Reply #3 on: October 10, 2011, 08:51:38 pm »
I would've told you Kevin had i known earlier!
Noel runs a motoplat on his 490, i think i need one of those 18mm decomps for my bike.. where did you get it?
Offline paul
Re: maico ign
« Reply #4 on: October 10, 2011, 09:17:14 pm »
83 /490s come stock with 18 ml  decomps  im told
Offline 09.0
Re: maico ign
« Reply #5 on: October 10, 2011, 09:42:21 pm »
Why then does a pvl work well on my '77 400?
Re: maico ign
« Reply #6 on: October 10, 2011, 09:56:08 pm »
I'll swap you my 490 pvl for your 490 motoplat so you can have your maico's all the same..
Re: maico ign
« Reply #7 on: October 10, 2011, 10:27:11 pm »
It's a totally different engine and probably has a different kickstart ratio, compression ratio and port timing all making it start easier.
Re: maico ign
« Reply #8 on: October 10, 2011, 10:40:14 pm »
you can get those decomps in australia
for half the price
i will find out for you ;)
Re: maico ign
« Reply #9 on: October 10, 2011, 10:55:58 pm »
He hasnt started it Johnny since he's lost all that weight.....might be different now. ;D
Re: maico ign
« Reply #10 on: October 10, 2011, 11:02:15 pm »
Ha ha ha...
Offline KTMaico
Re: maico ign
« Reply #11 on: October 11, 2011, 12:14:43 am »
John I got mine from Carl Bailey at Maico Only UK, I think Noel said he got his from Stackers at twice the price I paid.
1975 Suzuki RH250
1975 Suzuki RM125 S
