Author Topic: decompression valve. where from?  (Read 44826 times)
Offline Kane Mcguire
« on: October 08, 2011, 08:04:43 pm »
i want to fit a decompression valve to a big bore husky. where can they be bought? thanks.
Offline VMX60
Re: decompression valve. where from?
« Reply #1 on: October 08, 2011, 10:54:40 pm »
Here you go 14mm longreach for the Husky
http://vulcanworks.net/Compression-Releases-orderby0-p-1-c-1.html
« Reply #2 on: October 09, 2011, 12:34:55 pm »
thanks heaps!
« Reply #3 on: October 09, 2011, 03:28:24 pm »
try Les at mainly maico
Offline crash n bern
« Reply #4 on: October 10, 2011, 03:15:29 pm »
I've seen them being sold regularly on ebay somewhere for a lot less than those Harley ones.
« Reply #5 on: October 10, 2011, 03:16:39 pm »
got a few at home.
Offline PEZBerq
  • Brisbane
« Reply #6 on: October 12, 2011, 08:23:38 am »
Vulcan highly recommended but a little pricey I agree. I couldn't find any others on eBay that were 14mm with a long enough reach to stick out through the fins on the head. Not worth using cheap shit.
« Reply #7 on: October 12, 2011, 10:52:14 am »
I've used those Vulcan decompressors on my bikes for a few years and I swear by them. The only bike I can't use one on is the 360 RT1 motor in my Cheney because the exhaust goes right accross the 'spare' plug hole. These gizmo's are shitloads better than the OEM Yamaha and Maico items.
Offline asasin
« Reply #8 on: October 12, 2011, 11:10:10 am »
I have used one sucessfully on a CR 500 from a VICTA lawn mower.About $30 bucks from a mower shop
" zip on the do da your up and away"!
If in doubt ,WIND IT OUT
Offline huskibul
« Reply #9 on: October 12, 2011, 11:13:10 am »
  Are these(vulcans) difficult to fit to bikes that dont have spare plug hole's -   eg 83' huskies where there's not a lot of room from pipe etc -anybody done it ?
Offline HuskyPete
  • Huskys Only, maybe a CCM
« Reply #10 on: October 12, 2011, 11:54:49 am »
Shoey's Husky 430 and 500 head mods for decomp  ;)
Offline huskibul
« Reply #11 on: October 12, 2011, 12:19:53 pm »
    Great shot's 67 thanks for that ! looks fairly straight forward, damn nice 430 that one  :)
Offline KTMaico
  • "Love or Lust it's always a Maico"
    • Maico Lovers & Fans
« Reply #12 on: October 13, 2011, 12:35:28 am »
Used on my Maico 490, good product pity the guy at Vulcan Works I talked to was a complete dipstick. I have a couple spare.
« Last Edit: October 13, 2011, 09:36:36 am by KTMaico »
1981 Maico 490 (Special Build)
1979 Husqvarna CR250
1975 Suzuki RH250
1975 Suzuki RM125 S
1959 Mk1 Jaguar 3.4 4 speed manual with O/Drive
Offline Mike52
  • 81 KTM 125 LC
« Reply #13 on: October 20, 2011, 09:33:36 am »
Just bought a couple of the short ones and am going to try to fit one to a Wr400/85 head.
Watercooled so should be fun.
I have a genetic back problem and can't get enough movement/power in my leg to kick the old girl over + the compression on mine is a lot higher than the original 12/1 ;D
Will post pikkys if it works out.
If it don't then lesson learnt.  ;D
Offline KTMaico
« Reply #14 on: October 26, 2011, 05:13:37 pm »
For what it's worth, if I had to put in a decompression valve on any big bore bike I would not waste the time and money using 13mm ones (standard spark plug size). I will be changing my Maico 490 over to a 18mm one as soon as I can. The standard size units still don't give my bike enough compression release to make starting that easy. To start any bike bore bike they need a decent kick to get the fastest rotation of the motor as possible, (fuel suction, voltage/spark generation) and a 18mm decomp valve should give you maximum pressure release in your combustion chamber. I believe that the UK Maico owners tend to use the 18mm units over the standard.
Want any Vulcan Work Auto Decompression valves give me a call.
Kevin
1975 Suzuki RH250
1975 Suzuki RM125 S
