Author Topic: 83 CR250 water pump  (Read 8065 times)
Offline g465b
83 CR250 water pump
« on: October 07, 2011, 10:41:26 pm »
hi,can anyone suggest a cure ,fix,idea to deal with corrosion around the impellor on a 83cr250r
water pump.its 1-2mm deep from 7 to about 1 oclock around it,is araldite or a quick metal product
carefully applied a safe long term fix.what coolant is best to avoid further trouble.many thanks grant
Offline suzuki27
Re: 83 CR250 water pump
« Reply #1 on: October 11, 2011, 05:36:30 pm »
Hi Grant, I know some guys have used Devcon to restore the surface. I am pretty sure that any of the antifreeze/boil additives will help slow it down but draining it after a meeting would be the best bet.
« Reply #2 on: October 11, 2011, 07:05:03 pm »
before it got too late or too bad I sent mine of to Geoff Morris - GMC - who did a proper repair for me and a good one at that.
Best of luck.
Offline g465b
« Reply #3 on: October 12, 2011, 11:41:06 pm »
thanks for the advice
Offline ideasman
  • father of two bike loving boys
« Reply #4 on: October 13, 2011, 09:26:02 pm »
Used Devcon on mine, worked great no issues a couple of years later
Bets way to prevent it happening in the future, Keep riding it hard!
1985 XR80,1986 XR100,1986 RM80, 1984 YMF350, 1997 KTM400,1996 RM80, 2007 TTR90E, 1987 PW50.
« Reply #5 on: October 13, 2011, 09:47:25 pm »
devcon and the like aren't a permanent fix - eventually you will need further work and then they are a bugger to remove to do properly.
Offline motomaniac
« Reply #6 on: October 13, 2011, 11:52:18 pm »
did you end up selling your 83 Ross?
Offline Mike52
  • 81 KTM 125 LC
« Reply #7 on: October 14, 2011, 09:16:43 am »
The water sneaks around the back of the Devcon and continues nibbling away where you can't see it.
Sorta like termites.
You can end up with a real mess.
« Reply #8 on: October 14, 2011, 10:29:58 am »
yes I did MM - to a guy over east - just rang out of the blue.  Apparently it didn't sell in WA because people thought there was something wrong with it because it was so cheap  ???
Barney
« Reply #9 on: October 24, 2011, 04:09:13 pm »
Grant,
My son and I have had the same problem with the pump cover on an 84 CR250 - we have used JB weld (similar to devcon) but actually hardens to be able to be shaped with a grinding tip - has held up pretty well and with the coolant we are using no further detioration of the case seems to be happening - we are using a 50:50 water mix with Motul coolant (blue) which was recommended - so far so good.
Barney
Offline gra1961
« Reply #10 on: October 29, 2011, 09:04:47 am »
paper mache
Offline marshallmech
« Reply #11 on: October 29, 2011, 09:42:09 pm »
Disstilled water must be used with any coolant tap water is no good.
Andy Viper #70
Honda CR125 RB
Honda CR125RC
Honda CR125RA
Honda CR250RZ
Honda Z50A
Offline PEZBerq
  • Brisbane
« Reply #12 on: October 30, 2011, 12:04:58 pm »
Magnesium forms a protective layer of magnesium hydroxide naturally however chlorides attack it.  If the component is a magnesium alloy (guessing the Honda was) then any chlorides in the water (tap water) will attack the metal  :o :o. Even if coated any small defect in the coating will make the corrosion very severe at the location of the fault. Advise to keep coolant as free as possible from chloride by using demin water is correct. Draining the coolant is also wise but any trapped water will continue to cause corrosion so drain when engine is hot and remove hoses etc to allow water to steam out.
If attempting repairs the advice is not to use wire brushes or other iron based implements to remove the corrosion and prepare the surface for repair as the iron can cause further corrosion under the repair. Magnesium was not the smartest choice of material.....but is sure is light!
My 87 510 Husky has magnesium cancer of the barrel and the water pump flat surface (the pump casing is plastic) but since its 24 years old and not holed yet it should last my ownership  ;D ;D Later models reverted to aluminum alloy.
Offline g465b
« Reply #13 on: November 04, 2011, 08:50:31 pm »
many thanks guys for all the advice,spoke to the wiltec guys at mr vmx,they have used devcon on all their
water cooled CR hondas with careful prep of area and oats coolant !    Some great racing at mr vmx,for some
-I fell in first moto injuring my ankle,moto 2 hit a bike that went down right in front of me and tore my right
footpeg clean off,who needs two pegs when riding in sandy custardy slop.fun?
