Author Topic: YAMAHA XT200 1982 GEARBOX  (Read 1907 times)
« on: October 05, 2011, 04:55:07 pm »
HI i am after a YAMAHA XT200 1982 1X COUNTER SHAFT
                                                 1X KICK START IDLE GEAR
                                                 1X KICK START GEAR
Or whole gearbox and kick sart assembley if you dont want to part out.
Re: YAMAHA XT200 1982 GEARBOX
« Reply #1 on: October 05, 2011, 05:41:47 pm »
Got an XT225 Serow motor in bits here, if it's any use?
Offline smed
« Reply #2 on: October 05, 2011, 07:23:10 pm »
The AG200 cockys bike had basically the same donk except for the gearbox shifting pattern which was 5 up not 1 down 4 up & possibly different ratios if that helps widen your parts search,from memory they had a problem with cdi's going haywire and or the decomp cable breaking, the cdi causing backfiring & breaking kickstarter gears & side covers & the broken cable causing the decomp not to work causing similar problems ;)
Offline roy dale
« Reply #3 on: October 06, 2011, 08:10:59 am »
Hi mate i have the parts your looking for
www.japbikespares.com.au or 0410644974
« Reply #4 on: October 06, 2011, 12:21:02 pm »
Thanks everyone for your prompt replies :) hi Nathan would you like me to pm for what ya got or whats the best way to go? cheers
hi Smed thanks for your reply but will try the closest parts to origanal first but will keep you in mind, cheers
Roy Dale sounds good mate will get Baz to ring you, he's a mate of mine that wants the bits  :D
THANKS AGAIN EVERYONE:)
