Author Topic: YZ465H, YZ250H differences  (Read 2822 times)
Offline head
« on: September 30, 2011, 07:45:53 pm »
Would someone be able to tell me what the differences in chassis and swing arm are between a 465 and a 250 please. I intend to change mine to a 465 from a 250. Thanks.
Offline ARN
Re: YZ465H, YZ250H differences
« Reply #1 on: October 01, 2011, 08:26:05 am »
hi   i changed mine to 250 from 465 ,the frame is the same just needed the engine bracket from frame to head ,the swing arm on the 250 is shorter.
Offline head
« Reply #2 on: October 01, 2011, 08:28:39 am »
Did you use the shorter swing arm and how did it go.
Offline YZ250H
  • Back in QLD Baby !
« Reply #3 on: October 01, 2011, 08:49:15 am »
Are you sure I thought they were exactly the same  :-\
Offline ARN
« Reply #4 on: October 01, 2011, 11:06:20 am »
just checked the yamaha bible the 250g has the shorter swingarm ,the h frame on both 465 and 250
have a steepend rake by 1 degree compared to the g but they both have the longer swingarm.
i havent actually tried the shorter swingarm now that i have found this out i probably wont be as my frame is a h
Offline YZ250H
« Reply #5 on: October 01, 2011, 12:26:57 pm »
Fair enough.
As far as the roller goes I think they are identical ... almost.  The 465 has different handlbar mounts (rubber mounted).
Everything should bolt straight in if you are doing H for H.
Most people take off the headstay anyway.  The jury is out, but I've been told it causes the barrel to crack  :-\.
