Author Topic: Sealing Exhaust Flange's  (Read 2122 times)
Offline huskibul
« on: September 18, 2011, 11:28:34 am »
     What's the general consensus on using heatproof silicone in exhaust flange's on older two bangers-good or bad ? someone said you'll never tune them properly without it , is there any chance of it getting back into combustion chamber if it come's loose -  or other problems ? cheers
Re: Sealing Exhaust Flange's
« Reply #1 on: September 18, 2011, 01:14:53 pm »
I've been using some of that on my CZ as a lot of people recommend, let it sit for a couple of hours to get a good skin on the bead before you fit it to in effect make a o-ring type seal
« Reply #2 on: September 18, 2011, 01:43:25 pm »
I use that tape style muffler bandage. I wrap it around the end of the pipe that slips into the header flange making for a nice tight fit. I've been using it for over 30 years with no failures that I can think of.
« Reply #3 on: September 18, 2011, 02:33:16 pm »
Copper silcone works a treat and what damage could it do if it did ever go into the combustion chamber? Tony's skin trick is great aswell as giving it 24h to cure
Offline huskibul
« Reply #4 on: September 18, 2011, 03:49:53 pm »
   No worries fella's ! sound's like the way to go i'll give it a try-cheers
