Author Topic: 430 AE 84  (Read 7074 times)
Offline Michel Dufayard
430 AE 84
« on: September 18, 2011, 04:48:14 am »
http://www.imagebam.com/image/1fcc1b149859246
Hi guys
Here's my 430 AE almost finished ! :)
My first Automatic.
The HVA Forum is sleeping down under ! Winter ?
Springtime is coming. 8)
« Last Edit: September 18, 2011, 04:55:10 am by Michel Dufayard »
Offline Husky500evo
Re: 430 AE 84
« Reply #1 on: September 18, 2011, 08:02:29 am »
Hi Michel,
Nice bike. I am a huge fan of Husky autos. I have plans of building one like yours, only I was going to use an '86 CR500 top end, an AE500 crank (with 430 AE left half shaft) in 430AE crankcases, dropped into an '84 WR400 frame. This is the bike that I think that Husqvarna should have made  ;). I just hope that I don't run into clearance issues with the exhaust pipe header, as the 500 cylinder is about 10mm higher than the 430. I may also have to make the rear cone section of the pipe longer to suit the 500. I see that the tank on your bike looks like a cut down '83 alloy one . I imagine that this would have taken a lot of work . I intend to use the original WR400 tank, as it should bolt straight on .
Re: 430 AE 84
« Reply #2 on: September 19, 2011, 12:54:59 am »
There's still 2 or 2.5 cm above the exhaust.
« Last Edit: September 19, 2011, 12:57:18 am by Michel Dufayard »
Re: 430 AE 84
« Reply #3 on: September 19, 2011, 12:59:06 am »
Not too much work in fact. You grind the material to adjust the tank to the radiators and frame.
You bend the 2 alloy plates and ajust them. A professionnal do the welding.
« Last Edit: September 19, 2011, 01:14:24 am by Michel Dufayard »
Re: 430 AE 84
« Reply #4 on: September 19, 2011, 01:10:01 am »
Here, on my 510 TELC tank there has been more work !
« Last Edit: September 19, 2011, 01:13:07 am by Michel Dufayard »
Re: 430 AE 84
« Reply #5 on: September 19, 2011, 09:35:33 am »
Nice bike Michel. It's a shame Husqvarna didn't make a similar bike.
Offline mustanggrahame
Re: 430 AE 84
« Reply #6 on: September 25, 2011, 10:41:43 pm »
I guess I am more for originality. I don't get the rationale behind doing things like this.
Grahame.
Re: 430 AE 84
« Reply #7 on: September 27, 2011, 05:10:39 pm »
Passion and rationality are not in the same bag ! ;D
For these which ride 430 ae motors, what are your carb tuning ( main jet, needle, needle jet).
Michel
« Last Edit: September 27, 2011, 08:01:26 pm by Michel Dufayard »
Offline sa63
Re: 430 AE 84
« Reply #8 on: September 28, 2011, 05:29:40 pm »
I like it, especially if it puts together parts that have been lying around forever..
Re: 430 AE 84
« Reply #9 on: September 29, 2011, 05:02:44 am »
I 'm looking for a 83 alloy tank ( not 82) because I have only one tank for 2 bikes.
I need to make another one.
Michel
Offline sa63
Re: 430 AE 84
« Reply #10 on: September 29, 2011, 06:33:34 am »
what is the difference between 83 and 82?
Re: 430 AE 84
« Reply #11 on: September 29, 2011, 08:50:06 am »
No difference in '82 & '83 tanks except the color. There are 2 different sizes though, CR is slightly smaller than WR/XC.
Re: 430 AE 84
« Reply #12 on: September 29, 2011, 03:24:04 pm »
The 82 fuel hose touch the 83 side panels, not the 83 tank.
Offline PEZBerq
  • Brisbane
Re: 430 AE 84
« Reply #13 on: September 30, 2011, 07:57:06 am »
The WR tank is wider than the CR tank so that maybe the issue with fuel tap touching panel is due to tank model and not year?
Re: 430 AE 84
« Reply #14 on: September 30, 2011, 08:55:42 am »
I've checked all my tanks (7 of them) and one looks to be slightly bigger than the others and the fuel tap position may well be a few mm further out. I can date the others as '81/'82 for sure although not this one, so maybe the '83 was a tad larger. You learn something every day.
