Author Topic: 1969 GP5 IGNITION  (Read 2710 times)
1969 GP5 IGNITION
« on: September 09, 2011, 03:43:12 pm »
what is ther best ignition to go on these bikes there is a problem with the motoplat that is fitted at the moment
thanks
jim
Offline hitatreeonce
  • rather be an old fart than a young dickhead
Re: 1969 GP5 IGNITION
« Reply #1 on: September 09, 2011, 09:02:52 pm »
My 53m works fine on the stock gear the 33m has a later model breakerless setup proberly off a VR it works fine too
« Reply #2 on: September 19, 2011, 10:09:56 pm »
need a igntion for my 1969 250 gp5
what is the options for this
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
« Reply #3 on: September 20, 2011, 01:25:05 am »
Any of the later Montesa Motoplat electronic ignitions will fit.
Crank taper is all the same. Motoplat from the 74,75 and 76 250 mx
models would be your best bet. You will have to weld a tab to mount
the electronic coil.
