Author Topic: Identifying CR-M shocks  (Read 2692 times)
Offline JC
« on: September 07, 2011, 09:44:39 am »
I have a set of early (73-74) CR alloy bodied shocks that I'm trying to identify.
They have 12.5mm shafts & dual springs, one 5.5mm dia wire & the other 7.5mm dia.
Can any of the honda experts tell me if they're 125 or 250 shocks?
TJBLACKEN
Re: Identifying CR-M shocks
« Reply #1 on: September 09, 2011, 10:47:37 am »
My 73/74 CR250 is equipped with the stock shocks. The spring wire dia  measures 5.57mm on the smaller springs and 7.62mm on the larger. The shafts are 10.00mm.  Hope that helps.
« Reply #2 on: September 09, 2011, 12:01:12 pm »
I was under the impression that the 12.5mm shafts didn't come until '75 but not 100% sure.
Offline JC
« Reply #3 on: September 12, 2011, 08:59:59 am »
Thanks guys.
I did wonder if they might be 75 CR250M1 shocks, but as far as I can tell from pics in the 75 mags, they used a single spring per shock, not dual springs. (Of course, these ones could have been changed)
Can anyone confirm if the 12.5mm shafts only came on the 75 M1's?
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #4 on: September 12, 2011, 09:11:01 am »
i have a set of shocks here i think are from a CR, they were on my TY175 when i got it.
they have:-
10mm Dia shafts
12mm ID eyes
5.5mm Dia short spring
7.5mm Dia long spring
360mm eye to eye
but i have no idea what they are from
"flat bickie"
« Reply #5 on: September 12, 2011, 12:31:36 pm »
we just fixed 2 pairs for the nats to put on our bikes one set was off a 125 the other off a 250, they were differant only in the shaft size everything else looked the same ( inc springs) i think one was 10 and the other was 12 so im guessing your are 250 regardless of what year.
« Reply #6 on: September 12, 2011, 06:39:05 pm »
Thanks guys.
Yes the bigger shafts came out on the 125 & 250M1 models.
