Author Topic: Starting issues  (Read 5884 times)
Offline Bitten
  • Sydney, Australia
Starting issues
« on: August 30, 2011, 04:07:14 pm »
Hi all
Any suggestions to my starting issues would be greatly appreciated
I have just finished restoring an RM 465Z - including a full engine rebuild and it does not want to start....
Check list:
Good strong spark (new NGK as per the manual)
Fuel seems to be going through OK (BP98 @ 20:1 with Castrol TTR synthetic)
Strong compression
Engine turning over smoothly
I pull the choke on, on the 2nd or 3rd kick if wants to fire up, a few strong engine crackles then nothing, I kick it 20-30 times and nothing not a mumur??
I left it over night, rechecked everything, it looked like a fair bit of fuel has leaked from the overflow tube from the carby so I pulled it off, reset the float levels gave it a good blow through with contact cleaner. Checked the spark plug and strong blue spark. I did the same as above and same thing, on the 2nd or 3rd kick there were  a few strong engine crackles then nothing again I kick it 20-30 times and nothing.
Do I try and clutch start it down a big hill or am I just missing something obvious
Any thoughts as diagnostics are not my strong point!
Thanks in advance
Offline Bitten
  • Sydney, Australia
Re: Starting issues
« Reply #1 on: August 30, 2011, 04:12:04 pm »
Further to this I just went out and recheck and more fuel is slowly leaking from the overflow tube on the carby.
I know not too far ago there was a thread about something similar but do you think I can find it!!
Is this connected to the starting issues or something else all together?
Again any assistance is greatly appreciated
Regards
Re: Starting issues
« Reply #2 on: August 30, 2011, 04:44:29 pm »
The fuel issue could just be needle and seat.
Recheck all electrical earth places , when you painted the frame did you leave it bear under the coil? Is the stator backing plate nice and clean and on a unpainted surface.
Could be a huge air leak somewhere as well. Take off the Carby and the pipe , tip fuel into the inlet about a good cap full and kick her in the guts , if it fires up you at least know its not spark or air leak.
Re: Starting issues
« Reply #3 on: August 30, 2011, 04:51:38 pm »
Check list:
I'm with Slakewell the bar tender,check wiring,timing,cracked rubbers...recheck & check !!
good luck
Re: Starting issues
« Reply #4 on: August 30, 2011, 06:01:43 pm »
One thing that I do because I'm very lazy and like my bikes to start easy is to add an extra earth wire from the coil to the stator plate. Even more so with old motoplates.
Offline pancho
Re: Starting issues
« Reply #5 on: August 30, 2011, 06:03:23 pm »
 Try another new plug, Ive been caught with a crook brand new ngk on my RT1
 cheers pancho.
Offline KTMaico
  • "Love or Lust it's always a Maico"
    • Maico Lovers & Fans
Re: Starting issues
« Reply #6 on: August 30, 2011, 06:28:51 pm »
One issue that can catch out a re-build is, everything looks good to go and you can't work out what is wrong.... Good Spark, Fuel getting in (Wet Plug), Compression OK. Check that you have no air leaks getting into the cylinder via carby mounts, decomp valve etc... as this will lean out your mixture to a point where it will be very differcult to start. Also Check that you have the correct size pilot jet or your pilot jet is not blocked. If all else fails, buy a Maico 490.
Kevin
1981 Maico 490 (Special Build)
1979 Husqvarna CR250
1975 Suzuki RH250
1975 Suzuki RM125 S
1959 Mk1 Jaguar 3.4 4 speed manual with O/Drive
Offline D project
Re: Starting issues
« Reply #7 on: August 30, 2011, 06:33:07 pm »
Had the same problems with my RM500 when I restored it. With all the kicking over you may have a lot of excess fuel in the crank case. Check to see if you get a wet plug. You may need to drain the cases. I found that was my problem. Also you really need to get a good kick over at top dead center.They are always a B##ch to start.You could always try the old roll or tow start if you are desperate.But even then it is hard to do without locking up the rear wheel. Good luck ;)
Offline oldyzman
  • 250 two stroke!
Re: Starting issues
« Reply #8 on: August 30, 2011, 08:33:42 pm »
If the crankcase has a gut full of fuel, i would remove the plug give it a couple of slow kicks, dry the plug, put it back in. Try to start it with the throttle wide open. If you can get it to fire up be careful, it might start to rev its tits off. Just get ready on the kill switch, as it starts to rev up kill it momentarilly until it slows down then release the kill switch.
I once rebuilt a yz250F, i put the coils the wrong way around, ie the high speed in the load speed position.
Good luck brett
Offline Canam370
Re: Starting issues
« Reply #9 on: August 30, 2011, 09:00:35 pm »
If you have the plug out and are kicking it over to clear the lungs.......its obvious BUT don't forget to hold the kill button on or disconnect the electrics. If you don't fry the CDI then you might just fry the bike (fuel and spark!). I've seen it happen :o
Offline KTMaico
Re: Starting issues
« Reply #10 on: August 31, 2011, 10:43:38 am »
Another option if you are sure everything is correct is take out your air filter and use a can of "Start Ya Bastard" This will get the bike to fire. If everything is OK the bike will run, if not it will just fire and cut out. At least then you know you can look at the fuel and intake and rule out the ignition and timing. I hope this helps.
Kevin
1975 Suzuki RH250
1975 Suzuki RM125 S
Offline YZ250H
  • Back in QLD Baby !
Re: Starting issues
« Reply #11 on: August 31, 2011, 11:50:06 am »
Have you checked the timing with a timing light ?
Offline bazza
Re: Starting issues
« Reply #12 on: August 31, 2011, 02:59:32 pm »
elimination
spark - compression and petrol
Embrace patina
Offline Bitten
  • Sydney, Australia
Re: Starting issues
« Reply #13 on: August 31, 2011, 03:33:29 pm »
Thanks guys I will go through each of these and give it a try before I give up and pay someone to sort it out!!
Re some of you questions (Forgive me if some of my answers are pure ignorance!)
I have gone over it with a fine tooth comb and no obvious cracked rubbers or air leaks
The frame and coil mounts are powdercoated under the coil - Is this an earthing issue? The wiring diagram for this model shows an earth lead off the coil but the only earth lead that I have is from the kill switch which is onto a bare bit of frame
The manual states that the timing can't be adjusted on the 82 model and the stator was replaced in the correct position, so I am assuming timing is OK
I did check the spark and looks to be a strong blue arc on a correctly gaped new NGK spark plug
As I have a strong spark am I safe to assume that it is not electrical in nature
I will give some of the other tips a go and see what happens
I'll keep persevering for the time being
Thanks again
Re: Starting issues
« Reply #14 on: August 31, 2011, 05:20:07 pm »
No..never trust one wire  :P
reading post reply 122-130
http://ozvmx.com/community/index.php?topic=6469.120
Always a prosess of elimination-its vintage we have time.  ;)
cheers A
« Last Edit: August 31, 2011, 05:25:37 pm by VMX247 »
