Author Topic: Cleaning up old spokes  (Read 3659 times)
« on: August 28, 2011, 02:58:17 pm »
Any tricks for doing this without pulling the wheel apart?
Offline smed
Re: Cleaning up old spokes
« Reply #1 on: August 28, 2011, 04:44:39 pm »
Our ol mate TonyT put us onto this one, Autosol or The polish of your choice & a pair of those rough textured gloves that chicks use on there skin(Available from chemists & supermarkets,I got a pair from the cheap chinese shop in town), put em on,a bit of polish on the fingers & away you go ;) they wear out pretty quick so grab a couple of pairs :)
« Reply #2 on: August 28, 2011, 06:05:09 pm »
Depends on what sort of spokes they are, you have not mentioned that.
With old dulled up zinc ones you are pretty much wasting your time doing anything other than a good degrease and wash with detergent. Rubbing with any abrasives and polishes will just wear more plating off and promote more corrosion and rust and make them look worse so you are better off to leave them as they are or if you really dont want to strip the wheel then, just clean the spokes and then paint them with some silver paint, but be warned, after spending ages masking everything off that you dont want painted, you will end up think why did i not just strip the wheel and get the spokes re-zinced or replace with new ones. If you read the labels of most metal polishes they will say not to use on zinc coated surfaces as zinc plating is only thin and you just end up rubbing it off. Its not the same as chrome or nickel.
If they are not rust pitted, you can wire wheel the spokes and send them off to a zinc plater and they will come back like new. Its not very expensive.
If you have stainless steel spokes then yeah you can polish them up as much as you like.
« Last Edit: August 28, 2011, 06:11:46 pm by LWC82PE »
Offline dalesween
« Reply #3 on: August 28, 2011, 06:26:39 pm »
X2, good reply Leith, trying to make old zinc plated spokes look new again is virtually impossible without pulling the wheel apart and getting them replated.
cheers Dale.
« Reply #4 on: August 28, 2011, 06:30:56 pm »
Thanks guys, don't kow what they are yet, they're too manky to tell. They're on a 97 ktm300 i've just started rebuilding. I'll have a better look before I go any further. Cheers
« Reply #5 on: August 28, 2011, 06:44:36 pm »
If it's KTM they could be painted. My '08 250sx spokes are painted a silver/grey colour
Offline Mike52
  • 81 KTM 125 LC
« Reply #6 on: August 28, 2011, 08:33:03 pm »
Someone on this forum a while back mentioned chucking the whole wheel into a wheelie bin with molasses and water 1/9.
Magnesium rims are a no no.
Offline Graham
  • Fast TT meets Drunks Hill
« Reply #7 on: August 28, 2011, 09:23:31 pm »
If youre going to cut the old ones out make sure you measure the off set of the hub,ie place wheel on the ground place a  straight edge on the hub then measure down to the rim,do both sides this will help when you come to relace.
Gosh its a shame a slow 4 stroke trail bike can go so Fast !!
Taka 100
« Reply #8 on: August 28, 2011, 09:32:32 pm »
give FAT-TOY a yell he's onto some stuff that works a treat , i cant remember what he said , im going to have to start writing things down,  ;)
Offline frank jnr
« Reply #9 on: August 28, 2011, 10:01:14 pm »
Yeah, Mike52, BigK use's the wheelie bin molasses/water brew and works a treat.
Offline YZ250H
  • Back in QLD Baby !
« Reply #10 on: September 04, 2011, 09:08:52 pm »
So you are finally getting into that bike  ;D
Should be a cracker when you are finished - I didn't think there was a lot of money to spend on her to get her "going".
I thought the British beast was the next cab off the rank ??
Offline chrisdespo
« Reply #11 on: December 27, 2011, 10:00:21 am »
Velvet soap jex pads and a bit of water rub gently and you would be surprised
When in DOUBT GAS IT!!!
