Author Topic: 5-pack of quick Resto questions: 1980 KX125 A6  (Read 12249 times)
Offline Hardo
« on: August 26, 2011, 09:08:25 pm »
Hey guys. Restoring my A6 and have a few questions for the KX'perts ...
1. Is the swingarm originally anodized or painted silver? It appears to be a satin finish. I haven't put a magnet to it yet, but I assume it is alloy?? I am looking for the original look.
2. Has anyone found or know of a supplier for swingarm pivot bearings? I can find almost every other KX model... but not this one.  ???
3. Does anyone have a fuel tank for sale for an 80/81 KX125?
4. Does anyone have a PDF file or the like for a parts manual? (I know I can use babbitts/bikebandit/cmsnl/motogrid etc)
5. Is there a database somewhere listing the sequencing of Frame / Engine numbers for both the 80 and 81 model KX125's?
That's all for now.....   :P
Thanks in advance.... :)
TM BILL
Re: 5-pack of quick Resto questions: 1980 KX125 A6
« Reply #1 on: August 27, 2011, 02:42:50 pm »
Sorry cant be much help , but did you find a supplier for 78 / 79 model Sw arm brgs ?
IT400C
« Reply #2 on: August 27, 2011, 05:19:53 pm »
You can print the pages of the parts manual individually from the Kawasaki US site - perhaps even the Australian Kawasaki site.
I did this to get the parts manual for my KDX400, but I actually printed them to PDF, and then combined them into one file.
Tony
Offline Trent Farlow
« Reply #3 on: August 27, 2011, 05:45:16 pm »
Hi Hardo - the swingarm is alloy and is painted silver. I can let you know the swingarm bearing numbers in a few days as I have just rebuilt a KX250, i think they are available from bearing shops. . Your best bet is to buy a parts book on ebay. The parts books show the engine and frame number sequences, buy one for the A7 and it will have the A6 listed as well.  Sorry no tank. Cheers
Offline Hardo
« Reply #4 on: August 28, 2011, 10:15:20 am »
Cheers for the responses guys.
TM: sorry mate - I haven't looked earlier than 1980, but i will keep an eye out for you.
IT400: Thankyou, I just might do that. Have done it that way before.
Trent: Cheers mate! Thats exactly what I was after. It looks like it was painted originally but needed to ask. Do you know the paint colour exactly ? Does anyone out there know it?
Offline Hardo
« Reply #5 on: September 01, 2011, 09:39:48 pm »
Looks like I may be in luck on the swingarm bearings...
Seems the 80-81 KX125 bearings are the same as:
1984 KXT250-A1 Tecate SWING ARM ('84 A1)
1984 KXT250-A1 Tecate SWING ARM ('85 A2)
1985 KXT250-A2 Tecate SWING ARM ('84 A1)
1985 KXT250-A2 Tecate SWING ARM ('85 A2)
1980 KDX175-A1 KDX175 SWING ARM ('80 A1)
1980 KDX175-A1 KDX175 SWING ARM ('81-'82 A2-A3)
1980 KX125-A6 KX125 SWING ARM ('80 A6)
1980 KX125-A6 KX125 SWING ARM ('81 A7)
1981 KDX175-A2 KDX175 SWING ARM ('80 A1)
1981 KDX175-A2 KDX175 SWING ARM ('81-'82 A2-A3)
1981 KDX250-B1 KDX250 SWING ARM
1981 KX125-A7 KX125 SWING ARM ('80 A6)
1981 KX125-A7 KX125 SWING ARM ('81 A7)
1982 KDX175-A3 KDX175 SWING ARM ('80 A1)
1982 KDX175-A3 KDX175 SWING ARM ('81-'82 A2-A3)
1982 KDX250-B2 KDX250 SWING ARM
1982 KX125-B1 KX125 SWING ARM (KX125-B1)
1982 KX125-B1 KX125 SWING ARM (KX125-B2)
1982 KX250-B1 KX250 SWING ARM
1983 KDX200-A1 KDX200 SWING ARM (KDX200-A1-A2)
1983 KDX250-B3 KDX250 SWING ARM
 1983 KX125-B2 KX125 SWING ARM (KX125-B1)
1983 KX125-B2 KX125 SWING ARM (KX125-B2)
1983 KX250-C1 KX250 REAR SUSPENSION ('84 KX250-C2)
1983 KX250-C1 KX250 SWING ARM ('83 KX250-C1)
1983 KX250-C1 KX250 SWING ARM ('84 KX250-C2)
1983 KX500-A1 KX500 REAR SUSPENSION ('84 A2)
1983 KX500-A1 KX500 SWING ARM ('83 A1)
1983 KX500-A1 KX500 SWING ARM ('84 A2)
1984 KDX200-A2 KDX200 SWING ARM (KDX200-A1-A2)
1984 KDX250-B4 KDX250 SWING ARM
1984 KX125-C1 KX125 REAR SUSPENSION
1984 KX125-C1 KX125 SWING ARM
1984 KX250-C2 KX250 REAR SUSPENSION ('84 KX250-C2)
1984 KX250-C2 KX250 SWING ARM ('83 KX250-C1)
1984 KX250-C2 KX250 SWING ARM ('84 KX250-C2)
1984 KX500-A2 KX500 REAR SUSPENSION ('84 A2)
1984 KX500-A2 KX500 SWING ARM ('83 A1)
1984 KX500-A2 KX500 SWING ARM ('84 A2)
1985 KDX200-A3 KDX200 SWING ARM (KDX200-A1-A2)
Pretty much every Kwaka from the early 80's... hopefully its right.  :)
TM Bill:
From what I have found, the 78-79 Swingarm bearings are the same as this list....
This Kawasaki 92046-1001 BEARING,NEEDLE is also used on these models and components:
1974 KX125 SWING ARM-SHOCK ABSORBERS ('78-'79 KX125
1974 KX250 SWING ARM-SHOCK ABSORBERS (78-79)
1975 KX125-A SWING ARM-SHOCK ABSORBERS ('78-'79 KX125
1975 KX250-A SWING ARM-SHOCK ABSORBERS (78-79)
1976 KX125-A3 SWING ARM-SHOCK ABSORBERS ('78-'79 KX125
1976 KX250-A3 SWING ARM-SHOCK ABSORBERS (78-79)
1978 KX125-A4 SWING ARM-SHOCK ABSORBERS ('78-'79 KX125
1978 KX250-A4 SWING ARM-SHOCK ABSORBERS (78-79)
1979 KLX250-A1 KLX250 SWING ARM-SHOCK ABSORBERS
1979 KX125-A5 SWING ARM-SHOCK ABSORBERS ('78-'79 KX125
1979 KX250-A5 SWING ARM-SHOCK ABSORBERS (78-79)
1980 KLX250-A2 KLX250 SWING ARM-SHOCK ABSORBERS
Hope that helps a bit... :)
Offline rocketfrog
« Reply #6 on: September 02, 2011, 10:21:10 am »
Hardo, what dimensions are the needle rollers? There is a great little bearing joint in Raymo that have been able to supply most bearings and seals I have required at a decent prices. http://www.truelocal.com.au/business/terrace-auto-parts-and-bearing-centre/raymond-terrace nice guy to deal with and has heaps of stock.
Offline Hardo
« Reply #7 on: September 26, 2011, 08:16:58 pm »
Thanks Brando  (Rocketfrog) ... I just got a few gearbox bearings from them !   ;D  Top guys there.
Okay, I have it pretty well sorted... I have managed 4 of the 5 things I required.
The only thing I need is a Fuel Tank... PLEASE does anyone have one? It doesnt have to be perfect - just structurally good.
This is what it looks like... from what I can tell the 80 and 81 are identical, and even the 79 looks pretty close (??) .
Thanks KX'perts ..
tzeggy14
« Reply #8 on: November 06, 2011, 04:06:29 pm »
Lookin' good !!!
Yeah, I agree that the '79 tank appears to be pretty much identical. They definately didn't change from 1980 to 1981, I know that much.
The 80 and 81 125 were very similar. (I owned and raced both back in the day.)
A few differences:
Pegs:  Steel on the A6, alloy on the A7
Seat:  White graphic on the A6, green on the A7
Cylinder: 1980 had exhaust port bridge (low port height too) and good low/mid power. 1981 lost the bridge (raised port) and was a lot peakier.
Exhaust: From memory the '81 had a shorter header pipe and main chamber to compliment the peakier cylinder. They also fitted an alloy muffler to the A7 if my memory serves me as well as I'd like it to.
Frame: Slight mods to headstock area in '81 after frame breakages.
I've got a basket case A6 here myself, ready to begin restoring as soon as I can afford it. i have a real soft spot for these old KX125s.
Greg
« Last Edit: November 06, 2011, 04:14:49 pm by tzeggy14 »
Offline Hardo
« Reply #9 on: November 16, 2011, 08:57:20 pm »
Thanks for the tips Greg. I found a pretty good tank on ebay and restored it up.
That previous pic isn't of my bike.... I wish!!  :)
Here is a progress piccy of mine that I took yesterday.
Coming along pretty nicely. The re-sleeve job is ready to be picked up!
