Author Topic: RM Suzuki mufflers  (Read 17791 times)
Offline Doc
Re: RM Suzuki mufflers
« Reply #30 on: August 27, 2011, 08:37:37 am »
Yes Chris, I agree, the angle is not just a simple fix such as a shorter bracket. I found I had to cut and shut the stinger pipe to re-route maintaining original stinger length otherwise simply moving the pipe would have it hit the airbox. It's not the muffler that's the problem it's the pipe ;)
Offline mick25
  • Hunter valley NSW
« Reply #31 on: August 27, 2011, 08:43:01 am »
Theres a simple fix buy a yammie ;D
Offline suzuki27
« Reply #32 on: August 27, 2011, 08:49:31 am »
Lose the hose clamp and tack on a couple of loops to hold springs. Adjust the muffler tab so it mounts to the seat mount and paint it black. Whinge whinge !
Offline Doc
« Reply #33 on: August 27, 2011, 09:24:57 am »
what hose clamp? the original pic shows it mounted to the seat mount and it doesn't look much different.
Offline suzuki27
« Reply #34 on: August 27, 2011, 09:57:55 am »
My post was a bit late. I was looking at a photo that had the clamp!
Offline Doc
« Reply #35 on: August 27, 2011, 12:33:37 pm »
ah okay, now I see what you mean ;)
Offline 09.0
« Reply #36 on: August 29, 2011, 08:29:35 pm »
Gmc pipe and muffler. Not a great pic though.
« Reply #37 on: August 29, 2011, 08:50:31 pm »
Dont you just hate it when these "novice's" start putting up photo's of their bikes.....bloody show-off's ;D
Offline Doc
« Reply #38 on: August 29, 2011, 09:40:16 pm »
I still see the same issue Brad (or lack of issue depending on perspective) everything else looks stupendously wonderful but the muffler no matter how bling or bland still needs to follow the lines of the seat to fit the picture in my veiw. No doubt not everyone has the same veiw ;)
It's only a minor change but to me it makes the world of difference :-\ this is almost getting as bad as the footpeg saga ::)
« Last Edit: August 29, 2011, 09:51:31 pm by Doc »
« Reply #39 on: August 29, 2011, 10:00:55 pm »
The problem every manufacturer here has is that the chambers and mufflers have to be interchangeable with originals and other brands.
If you jig the chamber to suit the original muffler you end up with the same droop.
I think I did change the stinger on mine a bit to lessen the droop but from memory the stinger tube comes close to the frame tube / shock / side cover.
Reasonable clearance from these must also be considered.
« Reply #40 on: August 29, 2011, 10:08:48 pm »
It's just the dodgy tiler that fitted that one Geoff....mines straight as an arrow...he just needs to move the bracket up.
« Last Edit: August 31, 2011, 09:29:10 pm by Davey Crocket »
Offline steve7406
« Reply #41 on: August 30, 2011, 06:08:11 pm »
Hey Goeff whats your contact details and could post a picture of your muffler for a 1977 rm125b.
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
Offline Marc.com
« Reply #42 on: August 30, 2011, 08:26:38 pm »
Sweet swingarm knew my notion of applying a little gold to mine was heading in the right direction. 8)
« Reply #43 on: August 30, 2011, 09:16:39 pm »
Geoff does a mean HL500 too if your interested in something bigger  ;D
You can find them all over the place  :)
http://ozvmx.com/community/index.php?topic=18646.0
G.M.C. SINCE 1985 GEOFF MORRIS CONCEPTS
Ph. 03 5784 1446
Fax 03 5784 1442
e-mail [email protected]
Broadford Vic. Australia 3658 ...
« Reply #44 on: August 31, 2011, 09:26:09 pm »
