Author Topic: 360 piston to bore clearance  (Read 4125 times)
Offline shortshifter
  • Sunshine Coast QLD
« on: August 25, 2011, 05:08:13 pm »
started pulling my US ebay 360 engine apart today.Looked a bit untidy on the outside,someone had butchered a nice ACK manifold with 4 grub screws to hold on a carbi,countershaft sprocket welded on,barnyard screws holding all the covers in place,leaking a bit of oil through the countershaft seal.Head off,not too bad no carbon buildup,barrel off,piston out,measure up wow standard bore and piston according to CZ madness site.Undeside of piston scorched 450 main jet in the carbi I think means methanol.Hand cut gaskets under the barrel and the gear inspection plate of articles from a magazine from Houston Texas all working fine.big end tight with no play.Things are looking up.Can anyone who has a sidepipe manual tell me the recommended piston to bore clearance,will get the bore cleaned up and new piston.Off to work on that sprocket ???cheers
Re: 360 piston to bore clearance
« Reply #1 on: August 25, 2011, 05:29:28 pm »
Same clearance as a 380 would be my guess, new standard piston would measure 79.91 with bore 80mm
« Reply #2 on: August 25, 2011, 05:56:55 pm »
get all your info from this site and download manuals and parts lists
http://www.czmadness.net/
Offline foxy999
« Reply #3 on: August 25, 2011, 09:09:14 pm »
micheal gave me a copy of a spare parts list  for our 250 and 360 side pipe. do not know if it has what you are looking for but can bring it with us this weekend with the axle. micheal has written in the first three clearance in it. give lisa a call if you want us to bring it up with us. you can take it and make a copy.
My fastest lap is the first one :)
« Reply #4 on: August 25, 2011, 09:25:17 pm »
OK thanks guys :D
Offline foxy999
« Reply #5 on: August 26, 2011, 01:52:58 pm »
i made you a copy today, see you on the weekend.
