Author Topic: CR 250 73 gear box  (Read 2547 times)
Offline mick25
  • Hunter valley NSW
CR 250 73 gear box
« on: August 16, 2011, 07:01:50 am »
At mate of mine has a CR250 73 model with some gear shifting probs,
The gear shift shalf was bent so we replaced that, it made it a bit better but not right.
He has a MT250 75,76 model spare gear box, he was woundering if the internal gears shalfs etc... are interchangable with the CR one.
He wants to rebuild the CR gear box with new parts he can get, and if he can use the good bits from the MT box if he needs any bits that made
be good....I realise the CR250 have gear box probs but worth a try ...cheers mick
Re: CR 250 73 gear box
« Reply #1 on: August 16, 2011, 09:03:21 am »
mick
only the shafts and 3rd gear is the same the parts will fit but road trail ratios not good enough for race bike.try all the shift parts should be the same you can under cut the gears and this will stop it jumping out os gear
jim
« Reply #2 on: August 16, 2011, 09:27:11 am »
MR250 2.533 1.789 1.250 0.929 0.718
MT250 2.235 1.571 1.160 0.896 0.718
CR250 2.055 1.571 1.250 1.038 0.862
sorry second gear is the same
Offline mick25
  • Hunter valley NSW
« Reply #3 on: August 17, 2011, 07:00:24 am »
Thanks jim for your help will let my mate know ...
« Reply #4 on: August 17, 2011, 10:08:44 am »
later model gearboxes (76?) are supposed to fit and are supposed to be stronger!
