Author Topic: 76 yz250 head interchange. 77 78 fit?  (Read 4021 times)
Offline steveo247
« on: August 07, 2011, 09:46:49 pm »
new question, without starting another new thread with more of my silly questions.
is there any different between the 76 head, and the 77 78 models?
« Last Edit: August 10, 2011, 09:02:25 pm by steveo247 »
Offline motomaniac
Re: 76 yz250 crank interchange
« Reply #1 on: August 07, 2011, 10:55:17 pm »
can someone with one of those programs that search for parts interchangability tell me what other models a 1976 yz 250 crank will fit?
part number # 509-11400-00
thanks very much!
I dont have a program but I have a crank and later one also ,the dimensions are a bit different .Stick with 75/76 .
« Reply #2 on: August 08, 2011, 08:11:07 am »
Officially for 2 models, but others may fit!!
Part # = 509-11400-00-00
Part Description = CRANK ASSEMBLY
Model Count = 2
MX250B 1975 250 MX250 Off-Road
YZ250C 1976 250 YZ250 Competition Motocross
Offline steveo247
« Reply #3 on: August 08, 2011, 08:00:17 pm »
thanks for the info gentlemen. much appreicated
Offline steveo247
Re: 76 yz250 head interchange. 77 78 fit?
« Reply #4 on: August 10, 2011, 09:02:55 pm »
bump new question  ::)
Offline motomaniac
« Reply #5 on: August 10, 2011, 09:18:35 pm »
the pipe s are different so the 77/78 has fins cut to suit where the 75 /76 doesnt.Internally the combustion dome is off set to the rear on the later models.
« Reply #6 on: August 11, 2011, 09:46:11 pm »
Part # = 509-11111-70-00
Part Description = HEAD,CYLINDER
Model Count = 1
Part # = 509-11311-01-00
Part Description = CYLINDER
Model Count = 2
Part # = 498-15111-01-00
Part Description = CRANKCASE (LH)
Model Count = 4
DT250B 1975 250 DT250 Dual Purpose
DT250C 1976 250 DT250 Dual Purpose
Part # = 498-15121-01-00
Part Description = CRANKCASE (RH)
Model Count = 4
Clutch cover????
Part # = 509-15431-01-00
Part Description = COVER,CRANKCASE (RH)
Model Count = 5
IT400C 1976 400 IT400 Dual-Purpose
MX400B 1975 400 MX400 Off-Road
YZ400C 1976 400 YZ400 Competition Motocross
Offline steveo247
« Reply #7 on: August 11, 2011, 09:58:47 pm »
once again, many thanks!
Offline motomaniac
« Reply #8 on: August 11, 2011, 10:19:47 pm »
Webco heads are the best for these bikes.
« Reply #9 on: August 11, 2011, 11:03:21 pm »
......or some one with good knowledge of modern squish bands theory etc and re-machining ;).
IT400C
« Reply #10 on: August 12, 2011, 10:19:26 am »
I've riden a 400C with a D head on it and it went well - not sure about the 250, but it shouldn't be too different.
