Author Topic: Cr125 shock seals  (Read 2201 times)
Cr125 shock seals
« on: August 05, 2011, 02:23:28 pm »
Can anyone point me in the direction of seals for the rear shocks on a 125 CR 74 ???   are the 250 seals the same ????
Anyway where do they come from, what else fits or where are the cheapest ones.
Re: Cr125 shock seals
« Reply #1 on: August 05, 2011, 04:03:41 pm »
There are 10 and 12mm shafts. I have only personally seen 10mm though. The 10mm seals are 10 x 25 x 9.5 and the body o-ring is 30.8 x 1.9. Other parts should be inspected and replaced if necessary too. Those sizes are from specs for CR250M but i think the ones i have got are 125 and use the same 10mm seals too.
« Reply #2 on: August 05, 2011, 04:53:54 pm »
OK and where the cheapest place for these seal ?? can you get them from SKF  shop ????
« Reply #3 on: August 05, 2011, 04:55:57 pm »
is the 9.5 the ID or the width ?
« Reply #4 on: August 05, 2011, 05:47:56 pm »
Yes 9.5 is the thickness/height. OEM Honda part number is 91256-300-970 Im not sure if they are available new still. Otherwise yeah just try a SKF bearing dealer. You can get a head start and find the SKF number off their site. Its a little tricky to follow though, but if you can wait i will try and find it on the SKF site on the weekend, or just try Hoeys or one of the Elsinore parts specialists on the web.
Offline dkupf
  • Kinka Beach Qld
« Last Edit: August 05, 2011, 06:31:19 pm by dkupf »
