Author Topic: Montesa M7 case screws: Why??  (Read 3679 times)
Offline farmer58za
« on: July 31, 2011, 07:09:03 pm »
Hi All
Is there an underlying engineering reason why Montesa adopted M7 case screws and bolts for their engines? Or did General Franco's cousin have a huge shipment of the things going for a "very special price" ?
Regards
David
Dave's not here man
Offline Mike52
  • 81 KTM 125 LC
Re: Montesa M7 case screws: Why??
« Reply #1 on: July 31, 2011, 07:17:37 pm »
Why did the Russians invent their own metric thread system for the Belarus tractor. ???
To piss off anyone trying to fix them or because they could ?
Ah the mysterys of life ;D
Offline David Lahey
« Reply #2 on: July 31, 2011, 08:02:54 pm »
While we are having a bleat about Montesas how about:
The cylinder hold down nuts being an odd size internal hex
The gearbox output sprocket being mounted on a taper
The primary gear being mounted on a taper
The M7 thing is not confined to Montesas either, I seem to recall that OSSAs have them too
previous pseudonym feetupfun
Offline farmer58za
« Reply #3 on: July 31, 2011, 08:41:11 pm »
Ah, Franco's cousin was in there too...........
Dave's not here man
« Reply #4 on: July 31, 2011, 08:59:42 pm »
I though M7 must be the perfect size giving strength, durability and weight. ;D
dutchtwinshock
« Reply #5 on: August 01, 2011, 06:44:41 am »
M7 is a normale size italy france and spain
You can get them in every homeworkshop
« Reply #6 on: August 01, 2011, 12:09:22 pm »
YZA's and B's (250/360) use 7mm bolts in the cases around the crankshaft....extra stenght around the crank I guess without having to make the cases thicker if they went to 8mm.
« Reply #7 on: August 03, 2011, 08:09:01 pm »
KTM use them on sprocket bolts
