Author Topic: reg,s for mx track building ,any idea,s.  (Read 1356 times)
Offline suzuki447
« on: July 27, 2011, 09:37:55 pm »
g,day ,i,m building vmx track at the surfair speedway complex in moruya nsw. need some help with some reg,s on min width of track,lenght of track ,tyre wall heights,start gate width and any other things you guys might know has to be done to make track suitable  and pass MA reg,s .i couldnt find anything on line or with MA to help ,hope u can  thanks don.
bikes in shed.74tm125,76,78,82rm125s,...82,83rm250s.80canam qualifier.80,83yz125s.86yz490.80it125.76it400.80pe175and250.79rm50.76xr75.2xpuch50 magnums.jawa speedway.72honcho 90.84xr200.87xr100.phew thats all.
Re: reg,s for mx track building ,any idea,s.
« Reply #1 on: July 27, 2011, 09:47:26 pm »
Perhaps ring MA for a Track Guidelines Edition July 2011,the track will have to be inspected before ride day for an MA track event.....
seven meters wide  :o
outdoors not less than 400m and not less than 35sec lap time-perhaps skys the limit  ;D
Is it permanent or temp ??
and the list goes on ..................
good on you for attempting a vmx track build  8)
cheers A
Offline Shaun G
  • Sydney, NSW
    • FULL LOAD MOTORCYCLE TRANSPORT
« Reply #2 on: July 27, 2011, 10:21:16 pm »
Hi Don
A good starting point is here: http://www.motorcycling.com.au/PDF_Files/Club_Info/senior_junior_track_licence.doc
and there might be things you need to know here: http://www.motorcycling.com.au/PDF_Files/Club_Info/cl_mxsx_bylaws021210.pdf
If you need more info perhaps give MNSW a call.
Hope this helps.
Shaun
