Author Topic: D.I.Y airfilter  (Read 3398 times)
Offline TeeBone
D.I.Y airfilter
« on: July 25, 2011, 02:52:13 pm »
Hit a minor snag today trying to get a replacement airfilter, but have found the correct foam to be able to make one. Question is, what the hell do I use to bond it together at the seams???? Whatever it is, has to be fuel and oil resistant....anyone done this successfully?
Re: D.I.Y airfilter
« Reply #1 on: July 25, 2011, 03:11:48 pm »
Funny you ask that , i have a good finer filter i just washed and it came half unstuc ( well one of the joint did ).....   so was wonder what i could you to stick it back to gether
Re: D.I.Y airfilter
« Reply #2 on: July 25, 2011, 04:34:58 pm »
Never had a problem with Selley's brown/green contact adhesive. Their " new and improved" white stuff is useless, though.
Never had any joy gluing filters back together after they've been oiled - just can't get them clean enough.
Offline vmxrider
Re: D.I.Y airfilter
« Reply #3 on: July 25, 2011, 06:05:08 pm »
Could try sewing together.
Offline smed
Re: D.I.Y airfilter
« Reply #4 on: July 25, 2011, 06:16:44 pm »
Hot melt glue gun?
Offline shorelinemc
  • life sucks&then you die
Re: D.I.Y airfilter
« Reply #5 on: July 26, 2011, 08:57:46 am »
sewing does work with glue
Offline TeeBone
Re: D.I.Y airfilter
« Reply #6 on: July 26, 2011, 07:53:13 pm »
Thanks for the collective replies - have found a Kawasaki filter that should do the trick, if not I'll be making one pronto!
Offline D project
Re: D.I.Y airfilter
« Reply #7 on: July 26, 2011, 08:33:56 pm »
Had to make one for my bike, tried liquid nails etc. Ended up using clear silastic . Gave it a good bead and pressed together. Still seems to be holding up well  ;)
