Author Topic: IT175 J rebuild  (Read 3701 times)
coza778
IT175 J rebuild
« on: July 22, 2011, 01:27:29 pm »
progress is a little slow on this build but every step taken is a step forward  ;)
i bought this bike in reasonable good condition so the rebuild has been quite easy so far (no rusty or frozen bolts) there were a couple of broken lugs on the frame and also a hair-line crack just below the down tube
(mid welder fixed that)
thought i would share a few pics
before resto
stripped down
linkage bit
frame preparation
crack being repaired
more pics to follow
cheers corey
coza778
Re: IT175 J rebuild
« Reply #1 on: July 22, 2011, 01:33:39 pm »
frame painted
this is how far i am into the rebuild now, i'm just spinning up a couple of teflon rollers for the swing arm
http://s661.photobucket.com/albums/uu333/coza77/?action=view&current=Picture078.jpg
cheers corey
Re: IT175 J rebuild
« Reply #2 on: July 22, 2011, 01:39:03 pm »
You have an attentive group of admirers there Corey ;D.
And for good reason. Nice work. 8)
How was the frame prepared? Wire wheel and elbow grease?
coza778
Re: IT175 J rebuild
« Reply #3 on: July 22, 2011, 01:47:52 pm »
thank you Graeme  :D
frame prep was with paint stripper...about three separate coats then the almighty drill and wire wheel  :P
it's a bit of hard work but I had plenty of time to burn  :D
i also coated the frame with rust kill prior to priming  ;)
cheers corey
Offline vmx42
Re: IT175 J rebuild
« Reply #4 on: July 22, 2011, 03:12:02 pm »
Good to see you didn't paint on washing day!!  ;D
Nice work, keep the updates coming.
Re: IT175 J rebuild
« Reply #5 on: July 22, 2011, 08:07:22 pm »
Me thinks Doc has some competition :)
coza778
Re: IT175 J rebuild
« Reply #6 on: July 22, 2011, 08:28:43 pm »
G'day evo550
the pipe i had on the bike had a few hard hits....so I plugged both ends.. one end with an air valve and pumped about 30psi into it....then with the oxy popped out the dents...i will post pics in the day light...but I also mocked the 175 with an IT 200 DG pipe...damn close fit  ;)
not sure which pipe to go with (depends on the fit) cause i don't intend chopping the 200 pipe
cheers corey
coza778
Re: IT175 J rebuild
« Reply #7 on: July 22, 2011, 08:35:45 pm »
here's the wiring loom i prepared earlier...damn i hate wiring but it was all there and three hours later
hopefully when its installed it works  :P
this was the mess I started with
and what I ended up with  ;)
just need the ignition and speedo bracket....if anyone reads this and has one please PM me
thank you
cheers corey
Re: IT175 J rebuild
« Reply #8 on: July 26, 2011, 10:48:41 am »
I love seeing these - I admire anyone who does a resto involving wiring  :o
coza778
Re: IT175 J rebuild
« Reply #9 on: August 16, 2011, 02:26:25 am »
 ;D  ;D  ;D
my moto is...... we can do it... (and if we cant)  forums are great help  ;D  ;D  ;D
cheers corey
