Author Topic: Cappra 250 VB Primary drive  (Read 2648 times)
Offline farmer58za
« on: July 17, 2011, 07:58:58 am »
Hi all
I'm busy with a rebuild on my 250VB motor. The parts handbook shows a flywheel of sorts (6660.036) at the primary gear. A later revision of the parts book shows no flywheel.
My motor has no flywheel: http://s215.photobucket.com/albums/cc198/farmer58za/?action=view&current=IMG_4448.jpg  although according to the engine numbers on the handbook, it should have one.
Can someone please advise whether the flywheel should be fitted.
Thanks in advance.
David
Dave's not here man
Offline mike1948
  • Margate, QLD
Re: Cappra 250 VB Primary drive
« Reply #1 on: July 17, 2011, 05:17:46 pm »
I checked my V75 & VB parts books, they both show an auxiliary flywheel integral with the drive pinion.  I guess if it has previously been running without, shouldn't be a problem.  Most european bikes were fairly flexible with minor changes within model numbers.
« Reply #2 on: July 17, 2011, 06:11:50 pm »
I'm no Monty expert but I thought flywheel weight = enduro, no flywheel = MX. Otherwise the same.
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
« Reply #3 on: July 18, 2011, 02:13:24 am »
Only the Enduro models used an aux flywheel on the primary side.
Offline farmer58za
« Reply #4 on: July 18, 2011, 05:06:19 am »
Thanks all!
Regards
David
Dave's not here man
