Author Topic: Free To A Good Home.  (Read 2594 times)
« on: July 14, 2011, 06:51:13 pm »
Free To A Good Home ;D.
You pay postage or collect, fair enough ;)
Top triple clamp off something, probably Yammy.
All threads appear to be good (I'll confirm). 35mm.
This is the bottom triple clamp, minus head stem, for Yammy YZ250/400 D&E and maybe others (IT's???)
All threads appear to be good (I'll confirm). 36mm.
Offline oldyzman
  • 250 two stroke!
Re: Free To A Good Home.
« Reply #1 on: July 14, 2011, 10:17:40 pm »
I will take it off your hands please mx250.
Cheers Brett
just pm you mob number and i will cal you to arange...
« Reply #2 on: July 14, 2011, 10:45:13 pm »
Top clamp isn't Yamaha dirt bike - none of them had 35mm non-leading-axle forks.
Looks Euro, although they mostly had removable bar mounts (in my very limited experience).
Offline matcho mick
    • Moto Tumbi
« Reply #3 on: July 14, 2011, 10:50:44 pm »
is that carbon,or are they just painted black?, :P
« Reply #4 on: July 14, 2011, 11:26:58 pm »
No carbon there. No chance of being slugged by any taxes ;D.
You are seeing either dirt or grey primer overspray.
Offline Brian Watson
  • First Penton in OZ
« Reply #5 on: July 15, 2011, 01:14:49 am »
to my eye they are to suit something with forward axle forks...the legs are v close to being parallel with stem as is typical for forward axle forks..
« Reply #6 on: July 15, 2011, 07:55:44 am »
Definitely leading axle but also very close between the tubes. I'll measure and report ;).
Offline oldyzman
  • 250 two stroke!
« Reply #7 on: July 15, 2011, 08:49:12 pm »
I will have a look at the ones on my yz400d 2moro and compare, if they are off something else then someone else can put up thier hand for them as they would be of more use to someone else if its the case... Sounds like double douch - you know what i mean
Cheers Brett
« Reply #8 on: July 15, 2011, 09:07:57 pm »
400D has swept back bar mounts.
« Reply #9 on: July 20, 2011, 08:49:07 pm »
Back on the freebie market :D.
The bottom triples are the YZ250/400 d/e.
The top triples are off what I'm don't know :-\.
« Reply #10 on: July 21, 2011, 03:51:02 am »
yz250/400d/e were 38mm forks where the it's were 36mm if that helps anyone
