Author Topic: full width hub 21" front (pre 70)  (Read 1469 times)
« on: July 12, 2011, 09:11:02 pm »
Hi gents Im after a  full width hub and 21" alloy rim for a dt1 pre 70 last part needed for the nats
Re: full width hub 21" front (pre 70)
« Reply #1 on: July 12, 2011, 10:33:52 pm »
IF YOU GET STUCK I CAN LEND YOU STEEL FRONT WHEEL FOR THE EVENT
« Reply #2 on: July 14, 2011, 10:10:23 pm »
freaky you wouldn't belive it looking for something else in the man cave found a large hub dt1 21' wheel , note to self  "must have a sort out in cave" . Have you figgered out a price for the mx 250 less f/wheel, forks ,pegs , and top end yet?
« Reply #3 on: July 14, 2011, 10:43:16 pm »
i though you where getting back to me ?  i thought we had already discussed it and you said to wait ? Sent a few messages, and no parts came so i figured you moved on.
I pulled the motor down to suss it out would run fine had oil in it etc, but im thinking of putting new crank bearing in over the weekend as they are a little stiff, may free up with petrol/oil and a fire up.  Get back to me before it end up in another progect.  I bought a frame of mx250 and was goijng to put itin that down the track ??
« Last Edit: July 14, 2011, 10:46:25 pm by Freakshow »
