Author Topic: Cr 250 pre 75 forks  (Read 4980 times)
Offline Graham
  • Fast TT meets Drunks Hill
Cr 250 pre 75 forks
« on: July 12, 2011, 06:46:40 pm »
Can some one tell me the outside fork tube dia, and the over all lenght of these forks
Gosh its a shame a slow 4 stroke trail bike can go so Fast !!
Re: Cr 250 pre 75 forks
« Reply #1 on: July 12, 2011, 09:06:19 pm »
35mm. I could not tell you the length but they are supposedly the same as XL250. I have the measurement of those somewhere if it helps.
« Reply #2 on: July 12, 2011, 09:54:31 pm »
graham
1975 1976 cr forks are different to the 73 74
what do you want to know i have some cr and mt forks at home
they are 35mm in dia
jim
Offline Graham
« Reply #3 on: July 13, 2011, 06:00:38 am »
graham
jim
Well so far so good 35mm dia,is there a difference in the lenght,between these era's
« Reply #4 on: July 13, 2011, 06:19:54 am »
yes the 75 76 are longer and have a different top no nut like on the 73 74
Offline Hardo
« Reply #5 on: July 13, 2011, 01:23:20 pm »
The CR250M fork staunchions (chrome sliders) are longer by around 2". Both are 35mm as previously mentioned.
It's a good XL250 mod if you want more travel on the front. Everything is interchangeable between the CR250M (73-74) and the XL250 K0 (72-73) forks.
Only other obvious difference is the external speedo cable mount on the RHS.
Best person to ask for exact length is forum member Nathan S , as I just sold him a set of CR250M forks and I do believe he has XL bits as well to measure against.  ;D
Offline Hardo
« Reply #6 on: July 14, 2011, 12:51:10 pm »
oops sorry .... I meant Stan S , not Nathan S .....  :-\
Offline smed
« Reply #7 on: July 14, 2011, 05:23:07 pm »
I have my 73/74 250m in bits at the mo,the forks are still together, unladen(I.E. topped out) they are 820mm from top of fork cap to the bottom of the axle clamp :)
Offline Graham
« Reply #8 on: July 15, 2011, 05:57:57 am »
Thanks Guys looks all good I can fit the forks as they are the correct period.
Graham
