Author Topic: shocks to suit honda  (Read 4179 times)
Offline gdr
« on: July 10, 2011, 03:21:17 pm »
what are the best shocks to suit honda cr125 1974 model
HONDA THE POWER OF DREAMS
Offline flattracker
Re: shocks to suit honda
« Reply #1 on: July 10, 2011, 04:26:05 pm »
How big is your wallet?
« Reply #2 on: July 10, 2011, 04:47:58 pm »
Works Performance are a good shock without spending too much $$
Offline Kane Mcguire
« Reply #3 on: July 10, 2011, 05:46:23 pm »
look up gazi. i have had a set for 18mths and no leaks. perform great. same shocks on a lot of sidecars and no leaks either. had other shocks bought in oz and blew out after 6mths as have others i have seen. then its $90 for 2 seals! gazi is half the price and twice the quality. remote res alloy body rebound and compression adjustment  $810.00. a bargain
« Reply #4 on: July 10, 2011, 06:26:18 pm »
The Gazi's arent legal for pre 75 on a CR with the remote reservoir and I dont think they make ones 360mm long which is what they are on the Honda.....I can sell you a set of Works Performance shocks set up to suit you for about $500 with adj spring preload....they have been around for years and are proven....best bang for your buck so to speak!!!....pm me if your want more info.
« Reply #5 on: July 10, 2011, 07:28:02 pm »
sorry Wasp - I had a set of Works Performance - found them a bit improvement over what was on the bike (Konis) and around $500 delivered to the door.
Offline motomaniac
« Reply #6 on: July 10, 2011, 07:33:28 pm »
radial piston with shims to adjust if needed , 50 micron polished 36mm  steel bore for long life and very low friction, custom made in Australia and of course fully rebuildable .  ;)  Available from 15th of July .
but Works performance have a bleed and 3 ball bearing with springs that get softer with use so that you automatically get softer dampening as you get older. ;D
Offline dkupf
  • Kinka Beach Qld
« Reply #7 on: July 10, 2011, 09:16:18 pm »
Were can you get Works Performance shocks in Oz?? Darcy
« Reply #8 on: July 10, 2011, 10:22:17 pm »
I sell them (Im in Brissy), each set is made to order......ie...to suit riders ability, lenght, travel required, colors and type of bike etc.
Offline gdr
« Reply #9 on: July 11, 2011, 05:21:49 am »
email sent
Offline gdr
« Reply #10 on: July 11, 2011, 06:01:26 am »
flattracker what do you run on yours?
Offline flattracker
« Reply #11 on: July 11, 2011, 10:10:58 am »
I have a set of works performance on my flattrack bike. I got them off ebay for $240. I revalved them to suit myself as I couldn't find anyone in Aus that wanted to do it!! I added shrader valves while I was at it to make them easierv to regas! They are emulsion and seem to work quite well.
Offline gdr
« Reply #12 on: August 29, 2011, 05:07:47 am »
recived our works performance shocks friday,bolted them on and off to try them out saturday.perfect!.did not even need to adjust them.thanks davey crocket (john) great service. ;D
