Author Topic: next major build for pre 75 dirttrack  (Read 4127 times)
« on: July 07, 2011, 08:45:12 pm »
have enough parts to make a pre 75 cr250 flattracker
will have drum brakes front and back
Re: next major build for pre 75 dirttrack
« Reply #1 on: July 07, 2011, 09:22:31 pm »
I like the stream lined pipe  8) ...did you do the weld job etc ?
cheers A
Offline oldyzman
  • 250 two stroke!
« Reply #2 on: July 07, 2011, 10:38:39 pm »
Thats a slick unit Jim...
Brett
Offline elsie 125
« Reply #3 on: July 07, 2011, 11:03:08 pm »
sweet as jim, what brand pipe is that?
« Reply #4 on: July 08, 2011, 12:28:53 am »
looks like a DG without the plate
211kawasaki
« Reply #5 on: July 08, 2011, 10:12:12 am »
Disk could be an issue.....
« Reply #6 on: July 08, 2011, 10:46:36 am »
below the pics
will have drum front and back
« Reply #7 on: July 08, 2011, 02:10:59 pm »
that disk and hanger will be fine, but the vertical Nisfin/ Gremica master cylinders with a remote ressi wont be.
They still sell 'new' Airheart original master pods in the US for small machines, there exactly the same as the originals for only about $110.    IF you wanna stick with a disk in 70-75 period class fit one of them and you'll be good.
« Last Edit: July 08, 2011, 02:13:56 pm by Freakshow »
« Reply #8 on: July 08, 2011, 02:15:33 pm »
if you fit a rear drum and are only doing Dirt track, you wont need to fit a front one, leave the spooler on it. (or sell it to me)
Offline paul
« Reply #9 on: July 08, 2011, 02:53:08 pm »
you are build some beauts jim
