Author Topic: tm125 model query  (Read 2843 times)
Offline suzuki447
tm125 model query
« on: July 06, 2011, 06:23:00 pm »
gday ,i just bought tm125 in bits on ebay with engine no 32011 .any know what yr model it is .it also has a GEM brand aftermarket reed valve block and reeds and looks like an aftermarket pipe too,its under pipe but has a full lenght silencer welded on similar to elsinore .any ideas on reed unit and model thanks don.
bikes in shed.74tm125,76,78,82rm125s,...82,83rm250s.80canam qualifier.80,83yz125s.86yz490.80it125.76it400.80pe175and250.79rm50.76xr75.2xpuch50 magnums.jawa speedway.72honcho 90.84xr200.87xr100.phew thats all.
Re: tm125 model query
« Reply #1 on: July 06, 2011, 07:01:40 pm »
"vintage suzuki"  will be come  your new friend      1974 model
http://www.vintage-suzuki.com/tmnumbers.htm
« Last Edit: July 06, 2011, 07:05:19 pm by oldfart »
Offline suzuki447
« Reply #2 on: July 06, 2011, 07:40:09 pm »
thanks .didnt realize they had engine model list .did 74 model have reed valves or piston port as mine has a  what looks like aftermarket reeds and alloy housing with GEM on the side of it.any ideas.
« Reply #3 on: July 06, 2011, 08:15:40 pm »
GEM were an aftermarket reed system maker so not stock at all
Offline suzuki447
« Reply #4 on: July 07, 2011, 06:11:31 pm »
thanks tony ,did the 74 come with reeds or something else piston port ,i,m not sure .
« Reply #5 on: July 07, 2011, 06:23:50 pm »
All the TM's (except the TM75) were piston port engines.
« Reply #6 on: August 27, 2011, 09:57:10 am »
I had a spare pipe for my TM125L, it was as you decribed, it was a Bassani, it was a little quieter; gave better low-down but less top-end.  Always wanted a reed conversion for the TM to stop it 'loading up', although it never did as bad as the first few CR125's ;-)
