Author Topic: best front brake pre 75 and also pre 70  (Read 2680 times)
« on: July 04, 2011, 01:22:29 pm »
hi
need to get 2 front wheels for my dirttrack projects what would be the best brake combos ie honda pre 72 drums twin leading shoe in 21 in wheel, ect
first
pre 75 usa flattrack bike same as short track or tt
second
per 70 montesa cappra
thanks
Re: best front brake pre 75 and also pre 70
« Reply #1 on: July 04, 2011, 01:24:57 pm »
Certainly not Bultaco!!! J
« Reply #2 on: July 04, 2011, 02:03:05 pm »
YZ would be best front pre 75 , Maybe CZ pre 70
« Reply #3 on: July 04, 2011, 02:17:04 pm »
Isn't there a rule about not using road bike bits?
Those Monty twin leaders seem to be worth silly amounts of money.
Of the widely available dirt bike stuff, I'd suggest that the DT1/DT250 non conical brake is hard to beat for braking ability. The YZ/MX hub is a fair bit lighter, and the brake works well, but not as well as a DT brake.
« Reply #4 on: July 04, 2011, 02:44:35 pm »
 The Honda brake is heavy and powerful although the brake cam brings on the brakes suddenly. The Yammy 7 inch would give the same power with more feel. This can be varied with lining choice.
On DT the weight should be a issue although less weight is always a good thing for suspension performance (responsiveness).
« Reply #5 on: July 04, 2011, 03:25:41 pm »
how do you tell pre 75 mx yamaha front brakes from pre78
i think i have both
« Reply #6 on: July 04, 2011, 05:20:44 pm »
The cable mount on the brake plate vs the slot for the fork lug, is the clue. The non-leading axle ("pre-75") brakes run the cable parallel to the slot, while the later ones are at an angle.
Curly3
« Reply #7 on: July 04, 2011, 05:29:04 pm »
What do you want brakes for Jim ;D
Aren't they there just to get past scrutuneering?
Offline flattracker
« Reply #8 on: July 04, 2011, 06:56:39 pm »
Hey Jim no front brake only a rear. Still a little bit on the scary side trying to slow down!Puts the wind up the modern bikes with there front discs. All the guys at the club give me a fairly wide berth into corners at club days!!
Offline steve7406
« Reply #9 on: July 05, 2011, 04:08:17 pm »
Hey Flattracker nice bike where have you been hiding that bike i know i missed the last dt practice at broadford i didn't think you even had a bike like that let alone ride one.
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
Offline steve234
« Reply #10 on: July 05, 2011, 04:16:55 pm »
Those Mitas tyres look pretty neat, how do they go on deco?
Bultaco M106 Astro
Wanted: Dirt track bikes / parts / info
Offline flattracker
« Reply #11 on: July 05, 2011, 06:39:05 pm »
The tyres are great. They are speedway rears as both wheels are 19". I'm going to try to get to the next practice day, 17/7 but the one after that is in September on the 11th. I haven't been hiding the bike, it has new paint and a few other things after the first build, it has been around but only in undercoat,
