Author Topic: 1980 cr8o r/h case  (Read 2437 times)
Offline suzuki 400
1980 cr8o r/h case
« on: June 24, 2011, 09:42:36 pm »
hi ,does any body know which way round the right hand crank seal goes in the case 1980 cr80 as i have seen them both ways i have a logical idea of which way it should go but like i say i have seen it fitted flat side in flat side out ,thanks
Offline BETRIC
Re: 1980 cr8o r/h case
« Reply #1 on: June 25, 2011, 06:27:10 am »
I just had a look at genuine 1980 CR80R shop manual, looking at the diagram & photo of the R/H crankcase it looks like the flat side of the seal sits against the crankshaft, the photo shows the the crankcase laying on it's clutch side, so you are looking at the gearbox side of the crankcase with the flat side of the seal showing with main bearing behind it, the flat side of the seal has small lip around it's hole.
DELTEK, 72 MINI TRAIL, 73/4 XR75, 77/78 XR75, DG MONOSHOCK FRAME XR75, REDLINE FRAME XR75, PK RACING MONOSHOCK FRAME XR75, JWRP XR FRAME, SL70K1, 81 CR80RB, TY80A/B, YZ80A/B/D, GT50/80A, GTMX80A, 73 GTMX, GT1, COOPER MX, COOPER ENDURO,MX360A,MX250B,YZ125X MX100, 72 XL250, TC100,TL125, TY250C,IT250J
Offline suzuki 400
« Reply #2 on: June 25, 2011, 11:57:55 pm »
thanks i will put it in that way see how it goes pretty simple to pull apart thanks for the help ;D
