Author Topic: XR200 smokey  (Read 3175 times)
Offline DIRTPILOT72
XR200 smokey
« on: June 19, 2011, 12:18:35 am »
My 2 valve engine XR200 smokes a bit under  revs. Rings or valve seals?
Honda XR200 x2
Honda XR250
Yamaha Yamahopper QT50
Offline b490
Re: XR200 smokey
« Reply #1 on: June 19, 2011, 12:45:41 am »
Smoking (then clearing ) after decel/long idle ....most likely valve stem seals .
 If smoking all  the time under throttle /load , sounds like rings .
May be time to look at both.
Done a comp test ?
 How much oil is being used?
Looks like  top end rebuild needed
Regards ,
                 Steve
Offline The Wombat
  • I think I can I think I can
Re: XR200 smokey
« Reply #2 on: June 19, 2011, 08:11:16 am »
That's normal hahahaa just fill up the oil and check the fuel  ;D ;D
Offline DIRTPILOT72
Re: XR200 smokey
« Reply #3 on: June 19, 2011, 09:49:46 pm »
Constant and under load. Unsure about consumption as i have only ridden the bike once. I tend to think rings at this stage.
Honda XR200 x2
Honda XR250
Offline holeshot buddy
  • sunshine coast qld
Re: XR200 smokey
« Reply #4 on: June 19, 2011, 10:12:49 pm »
it will be the rings  :o
check your cranckase breather is not blocked first ;)
follow me to first turn
Offline DIRTPILOT72
Re: XR200 smokey
« Reply #5 on: June 20, 2011, 07:33:14 pm »
crankcase breather is pumping air out, i think rings, seems to be a common problem with the 2 valv motors. Should be easy to fix, might go high comp piston.
Honda XR200 x2
Honda XR250
