Author Topic: IT 465/490 Ignition.  (Read 2040 times)
« on: February 16, 2008, 11:48:49 am »
I'm looking for a full ignition (coil,stator,rotor) to suit an IT465. Perhaps IT490 igniton is the same so maybe that'll do too.
I need the heavy external rotor so YZ ignition won't be suitable for what I'm using it for.
Expat
Re: IT 465/490 Ignition.
« Reply #1 on: February 28, 2008, 06:57:17 pm »
Firko,
I have a loaner IT465 complete ignition system if you are in a hurry.
I will no be needing it for at least a year.
Just postage from NZ.
The big IT and YZ flywheels are same weight...the early big bore YZ 465 /490's did not use internal rotors...... Dont know about later ones though :-\
wesley
« Reply #2 on: March 01, 2008, 09:54:50 pm »
Firko....i have all that if you still chasing,i have yz,it or wr500 ignitions.
« Reply #3 on: March 02, 2008, 06:15:53 pm »
Thanks so much fellas but I've had a change of direction. I'm now going to use PVL ignition. It's been a 16 years since I modified the IT ignition for my DT1 racer and I'd forgotten the amount of welding and machining needed to fit it. Since I've retired I haven't got the machining facilities I had at my disposal back then. Also, PVL is far more modern, more reliable  and bolts straight on.
