Author Topic: RM370 KickStarter  (Read 3289 times)
Offline Toolboy
RM370 KickStarter
« on: June 01, 2011, 10:10:59 am »
Gday all,
I need a RM370 Kick starter.?????
If anybody knows will other models kisk starters fit this bike????
Appreciated
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
TM BILL
Re: RM370 KickStarter
« Reply #1 on: June 01, 2011, 11:32:41 am »
A or B model ? they are different  ;)
Offline Suzukal
« Reply #2 on: June 01, 2011, 04:52:43 pm »
I ordered 4 of them from Suzuki 3 years ago.
They seemed to have plenty.. i think it was around $140 ea.
Offline Husabergpete
« Reply #3 on: June 01, 2011, 09:24:30 pm »
Toolboy,
A and B are not actually different. They came out as an A with a fine spline and thinner shaft - can't remember the diameter but around 18mm. Towards the end of the A they brought out a new shaft and kickstarter which had a course spline and around a 2mm bigger diameter shaft.  Check what you have and let me know. [email protected] or 0407 915014 as I might have what you need.
All the best
Pete
Offline Toolboy
« Reply #4 on: June 03, 2011, 08:49:58 am »
PM sent Pete.
The shaft is 19/20mm course spline.
Engine numbers says A model
Thanks all
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
TM BILL
« Reply #5 on: June 03, 2011, 09:12:51 am »
Toolboy,
All the best
Pete
So 2mm bigger and courser spline isn't different  ??? my A and B kickstarts dont interchange for the reasons you state, so i assumed that made them different  ???
« Reply #6 on: June 03, 2011, 11:22:25 am »
Bill and Tim,
What I know is my A came from the factory with a fine spline. Once it snapped clean off in 2010 I did some research and found original Suzuki documents that said they worked out they were breaking and then made the larger course splined ones which appears to have been put on the last of the A's and then the B's.
Sorry if I got it confused in any way. Might have been a beer thing.
Tim, you should try Alpha Sports Suzuki in the USA for a course splined kick starter. I don't think you can buy the fine splined one or the fine splined shaft new anymore.
Pete
« Last Edit: June 03, 2011, 11:32:21 am by Husabergpete »
