Author Topic: TM400  (Read 5571 times)
Offline Toolboy
TM400
« on: May 31, 2011, 03:05:03 pm »
Gday all,
I have just purchased a 74 TM400L and looking for specification info or possible workshop manual online??
I need the following:
Fork oil + amount needed
Sprocket sizes
Carby main and pilot jet
I will be racing this bike so any further info from fellow TM racers would be appreciated
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Offline bazza
Re: TM400
« Reply #1 on: May 31, 2011, 05:51:59 pm »
TS400 electrics to help smooth wicked power band.
Embrace patina
Re: TM400
« Reply #2 on: May 31, 2011, 09:17:59 pm »
Pony up for decent suspension. Flywheel weight or TS ignition, decent pipe, 36mm Mikuni and away you go.
Offline Toolboy
Re: TM400
« Reply #3 on: June 01, 2011, 07:22:35 am »
Yes defiently the suspension upgrade + exhaust
Do you know if you can still purchase the flywheel weight and where??? I have read that it is an improvement.
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Offline Marc.com
Re: TM400
« Reply #4 on: June 03, 2011, 09:42:16 am »
Make one there are a couple of flywheels on ebay USA at the moment that have had the weight added so you can see how it should look. Remember needs to be brass/stainless or something non magnetic.
http://cgi.ebay.com/ebaymotors/TM400-1974-flywheel-rotor-magneto-fly-wheel-tm-400-/180626600423?pt=Motorcycles_Parts_Accessories&hash=item2a0e2f31e7
Personally I think a swap to TS ignition is a better idea, TM rotor only gives you the space for narrow flywheel weight that dangles off the end of the crank. Dangling heavy narrow discs at high rpm at the end of the crank smells like a great way to kill the main bearings. Plus flywheel weights back in the day were prone to come loose and fall off. Notice modern ones use the crank nut or extraction thread to hold them on.
Offline Toolboy
Re: TM400
« Reply #5 on: June 03, 2011, 02:38:09 pm »
Im still not so sure about the additional flywheel weight now that i have ridden the bike a few times, it is geared 15/45 which seems tall and gives smooth power but i have no idea what original or race set up is????
Thanks guys
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Offline frostype400
Re: TM400
« Reply #6 on: June 03, 2011, 07:10:00 pm »
Why every one is always trying to fix the tm400's I am going to run mine stock standard. ;)
1971 tm400 and PE's
Offline Marc.com
Re: TM400
« Reply #7 on: June 03, 2011, 07:15:01 pm »
Pathelogical desire to modify everything I guess, though I like my cars stock as a rock.
Re: TM400
« Reply #8 on: June 03, 2011, 07:31:46 pm »
In the history of motorcycling there have been motorcycles that the engine has conspired to kill the rider. There also have been motorcycles that the chassis has conspired to kill the rider. And there have been motorcycles that the suspension has conspired to kill the rider.
Fortunately there has only been a handful of motorcycles whose engine, chassis and suspension have worked together to conspire to kill the rider.
The TM400 is one such motorcycle.
Be afraid, be very afraid.
Offline frostype400
Re: TM400
« Reply #9 on: June 03, 2011, 08:34:33 pm »
Mine needs a bottom end rebuild and it is set to go the barrel is done new piston and rings I just need to spend a fortune and it will be done. :D
1971 tm400 and PE's
211kawasaki
Re: TM400
« Reply #10 on: June 03, 2011, 09:43:54 pm »
keep it standard, I have the busted cranks of some years with TM400s and I only learnt one thing, standard is best. Andy Caldercott raced one stock but his biggest tip was the rear shocks - they had to be off a TS185ER that was his big tip - and keep it standard 34mm carb and all.
Offline Toolboy
Re: TM400
« Reply #11 on: June 03, 2011, 10:58:47 pm »
Yes im defiently looking at keeping mine a sstock as possible with the exception of the rear suspension.
Any recommendations??????? Works Performance??? Ohlins would be nice,,hahahah 8)
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Re: TM400
« Reply #12 on: June 04, 2011, 07:26:18 am »
The 36mm Mikuni and reworking the transfers yields much better bottom end.
