Author Topic: husky forks banging when topping out. why?  (Read 2952 times)
Offline Kane Mcguire
« on: May 29, 2011, 08:00:21 pm »
82 cr husky forks when extended (topping)make a bad metal to metal sound. why? thanks.
Re: husky forks banging when topping out. why?
« Reply #1 on: May 29, 2011, 08:12:49 pm »
The nylon piston rings on the damper rods wear out and cause the forks to rebound too fast and then top out. You need to regularly replace those piston rings.
« Reply #2 on: May 29, 2011, 08:18:18 pm »
thanks. thought that but good to ask. thanks again.
Offline PEZBerq
  • Brisbane
« Reply #3 on: May 30, 2011, 08:17:38 am »
What weight fork oil are you using? Lighter oils will cause this top out clunk to be more pronounced. It relies on clearances between the damper rod and orifice to hydraulic cushion the forks at max extension.
Offline Husky Parts
« Reply #4 on: June 15, 2011, 10:10:45 pm »
Hi Kane ,
I checked stock this evening but unfortunately I do not have any at the moment.
Sorry cannot help you.
Thank you for calling
Fernando
0416198307
Offline Husky Parts
« Reply #5 on: June 16, 2011, 05:56:51 am »
Hi Walter,
What stickers, I am not sure what you are asking about, e- mail me at [email protected]
Fernando
