Author Topic: mx 250 cdi  (Read 2757 times)
mx 250 cdi
« on: May 23, 2011, 11:43:59 pm »
can someone tell me if there is any differances in the cdi boxes ?
I just traced a fault on the yz to the cdi box and if i look at my other bikes they looks to be the same as the MX250 -360 and the yz 125 ( sc500 was the same and sparked but was missing a wire 3was a 2..... between the lot of the 74-75 stuff only the last 3 numbers stamped on the case changed.    Ie  TIA01-06- #401, #807 etc
SO question is are they the same,
will they work the same and.......
are they safe to interchange ( dont really want to blow up a good working one ?
or do they have to match the stator ?
« Last Edit: May 23, 2011, 11:51:48 pm by Freakshow »
Re: mx 250 cdi
« Reply #1 on: May 24, 2011, 06:52:42 pm »
This will be very interesting for me as well, got a box full and trying to mix and match .
Re: mx 250 cdi
« Reply #2 on: May 24, 2011, 07:33:53 pm »
hi
if you guys buy the mx supliment for the mx250/360 sc500. it tells you what is compatible with what and the wire colours and ohms readings for what is good and what is dead.gave mine away with the mx250a i sold.all i know sc500 boxes have less wires than the 250/360.most people i know just junked the whole lot and fitted dt400/it400 cdi or pvl
jim
Offline KB171
Re: mx 250 cdi
« Reply #3 on: May 24, 2011, 08:41:23 pm »
We used a CDI box off a YZ 125x on the YZ 250B, It's still workin, if thats any help.
 KB
Re: mx 250 cdi
« Reply #4 on: May 25, 2011, 02:11:03 pm »
YEp it seem all the 125 250 and 360 YZ are the same ( well 125 to the c)
i fired this up on a Sc500 box so i know it will run on a 500 but id like to put the right one back on.  from what i can tell they are all the same but........ wanted to ask
Ianyz if you look at the stator there is a number on the bottom like M100 16 401.  you then match that top the same rotor that says M100 401 and also the hatachi box will go TiA06 ##  401  so its easy to match up a complete unit.
I was more interested in can you swap them around and if so what are the risks if any ( like blowing another CDi)
i have PVl on all my other bikes but this one was runnign fine so a cheap CDi will fix it, till i fall over another cheap PVL, beshides i have lotsa stators just runnigout of cdi's.
Re: mx 250 cdi
« Reply #5 on: May 25, 2011, 04:44:04 pm »
on another note does the pulsar have a fixed point ?  i thought the key on the Right was lined up with a little spanner thing, but a few of them i see are lined up in differ places ??? idea or comment.
