Author Topic: Clutch plate specs  (Read 2458 times)
Clutch plate specs
« on: May 20, 2011, 06:05:36 pm »
Does anyone know the correct thickness of the steel plates in a 73 380, when I got mine apart I found 2 plates were around 50% thicker than the other & not due to wear as they're flat not grooved
I haven't seen anything giving a actual size but did read something about the earlier bikes having 5 plates instead of 7, my thinking is that the thinner plate would be correct & the other 2 are for the earlier pre70 clutch
Any thoughts?
« Last Edit: May 20, 2011, 07:19:17 pm by tony27 »
