Author Topic: '74 WR400 output shaft end float  (Read 2886 times)
Expat
« on: May 19, 2011, 08:47:53 pm »
Can anyone please tell me what correct end float should be on output shaft ( sprocket shaft) for '74 WR400 6 speed?
I thought shaft had excessive end float when I acquired it.Trans has been apart before so I disassembled and checked all parts against parts book and fitted new bearings yet shaft end float still  seems excessive compared with my '75 CR360GP 6 speed which has almost no end float.  ???
Offline Huskydoggg
Re: '74 WR400 output shaft end float
« Reply #1 on: May 27, 2011, 03:26:15 pm »
My freshly rebuilt '74 CR400 measures about 0.025" endplay. I looked at two 400 parts bikes and they are about the same.
Steve
Offline Gippslander
« Reply #2 on: May 28, 2011, 01:06:35 am »
my 73 cr250 with splined shaft update -- same box I think has very little play -- would not be 20 thou'
If you've got more somethings probably not right -- there are hardened steel shims/washers on the shaft to space everything out and with them in place my box has very little play
Expat
« Reply #3 on: May 28, 2011, 09:27:00 pm »
Thank you gentlemen.
I will open it up again for a thorough inspection
