Author Topic: wanted for 82 250 performance pipe/ mossbarger reed  (Read 2230 times)
Offline Kane Mcguire
« on: May 17, 2011, 09:56:23 pm »
wanted. any performance parts for 82 husky 250. thanks.
Offline Brian Watson
  • First Penton in OZ
Re: wanted for 82 250 performance pipe/ mossbarger reed
« Reply #1 on: May 20, 2011, 10:21:24 am »
To my knowledge, the only parts that were around were handled by Pro Circuit in the US... you could get an Asch pipe...only ever saw one here on the West Coast.... and as for Mossbarger...I have a complete Mossbarger reed set up for a 430 which is quite a bit different (larger) whilst still using the original pattern bolt on...but the 250 arrangement is quite different and not sure about how the Moss would/will fit...the 250 has a built in main reed block as part of the cylinder... Mossbarge are still manufacturing as week speak...so maybe you could contact them and see
« Reply #2 on: May 20, 2011, 12:11:28 pm »
Mine's stock standard except for an '85 alloy muffler, just fesh and has more than enough power. I'm actually thinking about changing the small internal rotor to an XC external set up for a bit smoother power. It's as fast as anything in the class and leading VIPER over 45 all powers after one round. They don't need hotting up unless your in the top 3% who can use it.
« Last Edit: May 20, 2011, 04:15:59 pm by bigk »
« Reply #3 on: May 20, 2011, 08:16:31 pm »
i can use it
