Author Topic: Please Identify this frame  (Read 4898 times)
SAABCOMBI
« on: May 16, 2011, 06:25:52 pm »
The Frame is a CZ,
Type 969
capacity 361
Frame  969-01-02293
Year date -19
Re: Please Identify this frame
« Reply #1 on: May 16, 2011, 06:27:39 pm »
Sounds like a sidepiper to me but I could be wrong & it's a twin pipe
« Reply #2 on: May 16, 2011, 06:43:14 pm »
david check this web page out
http://www.czmadness.net/specs/cz400.html
SAABCOMBI
« Reply #3 on: May 16, 2011, 07:28:34 pm »
What would be the differents in each frame., This frame footpeg have a thread, plus the normal attachment like my montesa foot peg set up. It main front  frame tube goes down under the frame cradle.
SAABCOMBI
« Reply #4 on: May 16, 2011, 07:33:01 pm »
The 34 hp 6400 rpm, 109 KG, convert to pounds is 240lb, going by the spec`s that you gave me its a sidepipe frame, comparing the two, twinpipe and sidepipe their is very little differents. but l would still like to know the differances between the two frames.
« Last Edit: May 16, 2011, 07:40:40 pm by 33M »
« Reply #5 on: May 16, 2011, 07:53:15 pm »
david
your frame is a sidepiper you kneed to ask 090 the difference as he has both
SAABCOMBI
« Reply #6 on: May 16, 2011, 07:55:49 pm »
Cheers Jim, their is know need as l have worked out the differances.
« Last Edit: May 16, 2011, 08:18:09 pm by 33M »
090
« Reply #7 on: May 16, 2011, 08:29:54 pm »
The Frame is a CZ,
Type 969
capacity 361
Frame  969-01-02293
Year date -19
969 is 360 twin port
969-01 (your number) is side pipe.
Main differences are,
frame tube that runs from swing arm pivot bolt up to main frame tube under tank is curved or bent and meet the main tube at a different point.
Second exhaust mount at rear which is the obvious thing.
Side number plate mounts in different positions.
And most importantly...is it for sale?
Offline paul
« Reply #8 on: May 16, 2011, 08:38:05 pm »
ive just checked ebay and no sign  off it yet ;)
SAABCOMBI
« Reply #9 on: May 16, 2011, 08:41:17 pm »
I may as well be as l don`t have any use for it at this stage, it was delivered today from the USA. I bought it to fit my jawa engine in it, the frame is in excellent condition. Paul l was about to make an offer on your maico 400 but after that comment your out of luck. ;D
« Last Edit: May 16, 2011, 08:44:26 pm by 33M »
090
« Reply #10 on: May 16, 2011, 08:51:01 pm »
How much Dave?
Offline paul
« Reply #11 on: May 16, 2011, 08:55:56 pm »
now dave you carnt blame me for haveing a quick look on  ebay ,i never know what you will be up to next
Offline paul
« Reply #12 on: May 16, 2011, 08:56:51 pm »
ill take the frame as a deposit ;D
SAABCOMBI
« Reply #13 on: May 16, 2011, 09:10:29 pm »
Just Kidding Paul :D
SAABCOMBI
« Reply #14 on: May 16, 2011, 09:12:14 pm »
Make me an offer if l like the offer l will PM you Brad
