Author Topic: Early TS & TC front hubs  (Read 1742 times)
« on: May 12, 2011, 11:09:36 pm »
Does anyone on here own one of the following TS or TC front brake plates below and can tell me the number of teeth on the speedo drive pinion. I can not find the amount of teeth listed online for this part, only the other gear which is 54611-28001 and they list that as 28 teeth. I just need to know the pinion teeth count though. Maybe someone has a printed parts book that lists the teeth because no online stores do. The pinion will come out after you unscrew the bushing. Pointly pliers normally works.
Thanks for your help.
Part # = 54621-28000 (supercedes to 54621-28001)
Part Description = PINION,SPEEDOMETER
Model Count = 29
TC100B 1977
TC100K 1973
TC100L 1974
TC100M 1975
TC125A 1976
TC125B 1977
TC125J 1972
TC125K 1973
TC125L 1974
TC125M 1975
TC185A 1976
TC185B 1977
TC185L 1974
TC185M 1975
TS100A 1976
TS100B 1977
TS100C 1978
TS100K 1973
TS100L 1974
TS100M 1975
TS100N 1979
TS100T 1980
TS100X 1981
TS125J 1972
TS125K 1973
TS125R 1971
TS185J 1972
TS185K 1973
TS185R 1971
« Last Edit: May 12, 2011, 11:11:32 pm by LWC82PE »
