Author Topic: CR450 strange arm  (Read 2931 times)
Quicksilver
CR450 strange arm
« on: February 12, 2008, 08:26:54 pm »
Honda men...
I have a strange one for you to look at.
Has anyone ever seen a CR450 arm like this before.? The bottom arm in pictures. It has extra support bracing around rear wheel mounting plates. I believe it is original, I doubt its an add on or after thought the workmanship is way too good and clearly as old as the rest of the bike. It is not a repair as no damage to plates or repair work can be seen anywhere on the arm.
Any clues? . The other arm is same as all the other CR450s arms ive seen. I have trolled the net looking at a number of CR450s. All have the same arm as one pictured on top. The heavier arm seems to be is identical as far as I can tell in all other areas.
[attachment deleted by admin]
Quicksilver
Re: CR450 strange arm
« Reply #1 on: February 12, 2008, 08:29:51 pm »
Quicksilver
« Reply #2 on: February 12, 2008, 08:33:18 pm »
2
Offline VMX Andrew
« Reply #3 on: February 12, 2008, 08:57:41 pm »
could be a factory racer item...
magoo
« Reply #4 on: February 12, 2008, 09:09:30 pm »
It's certainly not standard
