Author Topic: YZ400 D frame  (Read 2833 times)
Offline motomaniac
YZ400 D frame
« on: May 03, 2011, 06:31:40 pm »
If anyone has a spare frame for a 77 YZ400D in reasonable nic  please PM Me. Thanks
Offline motomaniac
Re: YZ400 D frame
« Reply #1 on: May 03, 2011, 06:32:33 pm »
Can buy or I have some YZ and IT stuff to swap .
Offline crossedup2
  • Never enough shed time.....
Re: YZ400 D frame
« Reply #2 on: May 03, 2011, 07:54:03 pm »
If your not particular, the YZ250D and the YZ400E are the same frame just different numbers.
Peter B
Offline motomaniac
Re: YZ400 D frame
« Reply #3 on: May 03, 2011, 08:08:24 pm »
Peter B
Thanks , wasn't sure about the 250D .The 400E will intercahnge but not sure about the issues for pre 78.Would prefer to stay safe with a D model.
Offline crossedup2
Re: YZ400 D frame
« Reply #4 on: May 03, 2011, 10:01:50 pm »
Hi Moto
I have the YZ400E frame with the D steel swing arm.
It's nearly ready for competition. According to the Yamaha parts list the only difference between D and the E 400's is the clutch and the arm. In this case I'd argue that the frame numbers doesn't matter as it has all the other relevant parts that make it a D.
Peter B
Re: YZ400 D frame
« Reply #5 on: May 04, 2011, 07:16:15 am »
I have some bits of YZ 250 D frame but the frame has been cut up.
Re: YZ400 D frame
« Reply #6 on: May 05, 2011, 01:13:12 pm »
I repaired some frames a few years ago, a 400 D & a 400 E
Although they look very similar at first glance there is actually a few differences in gussets and bits.
Also if I recall correctly one of them has a lower engine mount under the cases and one doesn’t, can’t remember which one is which.
The 400 D 1W4 bare frame weighed in at 11.6 Kg’s
The 400 E 2X4 bare frame weighed in at 10.3 Kg’s
Offline roy dale
Re: YZ400 D frame
« Reply #7 on: May 06, 2011, 08:28:00 am »
Hi mate
have a yz400 frame 2X5 1979 if that is any help
[email protected]  or 0410644974  roy
Offline motomaniac
Re: YZ400 D frame
« Reply #8 on: May 06, 2011, 03:30:47 pm »
400 E is 2k8 Geoff . 2X4 is 250 F ,2X5 is 400F. The F's had the lower engine mount and so did the 250 E which was the first model to change to the newer smaller cased engine with the middle mount. 400D =1W4 and 400E = 2K8 are old style no middle mount frames.
Re: YZ400 D frame
« Reply #9 on: May 06, 2011, 09:59:42 pm »
Well there you go.
Customer didn’t know what he had. He did swear it was a 400 though so must have had a motor swap at some stage.
Lucky I noted the frame No’s.
