Author Topic: comp kit - shed engineers come forth  (Read 45001 times)
Re: comp kit - shed engineers come forth
« Reply #15 on: August 09, 2007, 02:55:23 pm »
Lozza like i said im taking a whole fricken bike with me that works and will swap over every thing until it purrs !.
I has a brand new mukuni and Betta bikes tested the electrics, what ever it is is hidden.  IF i peice out bit by bit it will have to go, then ill reverse engineer until the last piece i put on/ take off is in my gunsights.  ( then it will end up being a stuck kill switch ) ooh hango on a sec  ;D
« Reply #16 on: August 09, 2007, 10:46:43 pm »
Cracked intake manifold rubber?
Rosco400
« Reply #17 on: August 09, 2007, 11:05:12 pm »
Lozza pulled my barrell off after and had hairline crack on baseline both mounting holes which couldnt see with motor in bike, actually fell off in his hand, apparently happened to a few of the early bikes, might be worth a look, mate who also recently purchased rm370 found same prob on his and few posts on old forum pointed this way ???
« Reply #18 on: August 10, 2007, 08:23:39 pm »
yes, but it idles ok it wont hunt off. also it dies when you ride, but revs its nuts when you twist on stand.  Im trying to get down there tomorrow to start on this sarga again.
Yes the intake rubber is cracked, have stuck silicon over to see if it made any doifferance = none at all
Rosco whats a baseline ? what fell off in your hand, part of the barrell ? im lost on where you are help me get my bearings on where you are point ing me.
Rosco400
« Reply #19 on: August 11, 2007, 02:54:45 pm »
base of the barell where four mounting bolts pass through, if barrel not pulled flat down on cases, vibration can crack around mounting points, base of barell actually broke away on one side of the rm465 through mounting bolt, hairline crack around other, i like you was thinking blown crank seals at first and prepared for leakdown test, same symptoms as what your saying, very hard to see so clean with degreaser and get bright torch and put your best magnifying glasses on, look very closely around mounting holes, baseline probably not best wording, sorry freaky :-[
« Reply #20 on: August 12, 2007, 08:59:35 pm »
did you take piccy ? id be interested to see it for future referance, can you post it for us
