Author Topic: Gasket for YZ 360B  (Read 2255 times)
Gasket for YZ 360B
« on: April 30, 2011, 03:08:04 pm »
Gents - does anyone have available for purchase a clutch side gasket for a YZ 360B - part number is 308-15461-01-00.  Need one as soon as I can if at all possible.
thanks in advance.
Rossco
Re: Gasket for YZ 360B
« Reply #1 on: May 03, 2011, 06:44:14 pm »
Rossco would not a rt/dt gasket fit .
Offline Brian Watson
  • First Penton in OZ
« Reply #2 on: May 03, 2011, 07:39:08 pm »
Ross..bring the cover around to the old boys place and he will make you a gasket for a carton...of coke..
« Reply #3 on: May 03, 2011, 08:23:19 pm »
i just put a 308 on botht he 250 and 360 and it fit the clutch cover no probs, you can aslo use the 275 one but up at the top near the kick starter it has more and you need to snip it and take a little bit out, i remebr i used one on my 360 case when i realised it was too long in that section maybe cut out 5mm and then stuck the 2 end toghether worked fine and all holes lined up.
i suspec the Dt1-2 fit as well and the Rt1-2 i think the issue was the rt3, but dont qote me.  they all fit just the 275 prefix needs to be shortend at the kicker which is a 2 sec job.  there about $1 on ebay or a full set is $9.95 plus postage.
« Reply #4 on: May 04, 2011, 04:19:46 pm »
my mistake the 275 is for the real ealry long fatter side cover with the  bigger kickstarter so the 275 code is that first series.
So any of the the other one 284,308,322,211 and 286 being all the same fit right on and be about $2 each on a bad day.
« Last Edit: May 04, 2011, 04:28:55 pm by Freakshow »
« Reply #5 on: May 04, 2011, 07:32:51 pm »
thanks gents - and Watto  ;D.  Have a new clutch cover but went through the bits and pieces and no spare gasket.  Brian - am back at work now so probably easier to just ebay one like the guys have mentioned - thanks though as Iw as hoping someone had one spare  :'(
