Author Topic: 1974 cr125  (Read 1721 times)
Offline dodgee
1974 cr125
« on: April 27, 2011, 04:17:44 pm »
wanted top triple clamp and forks 4 a 1974/5 cr125
Re: 1974 cr125
« Reply #1 on: April 27, 2011, 07:19:23 pm »
will swap a good set of cr125 forks currently being used in my YZ125a and in good condition with no pits no leaks - swap for some forks from yza/b,mx400b,250B etc. (see joan for details)
will also swap with the complete front CR Wheel and Backign plate on it too if you can pull me a rear or front YZ for a swap-see too   :)
may have other stuff to trade, but will check
« Last Edit: April 27, 2011, 07:22:04 pm by Freakshow »
Offline holeshot buddy
  • sunshine coast qld
Re: 1974 cr125
« Reply #2 on: April 27, 2011, 10:10:58 pm »
wayne i might have some triples what do
they look like (dont say they have holes in them for forks) ::)
follow me to first turn
Offline dodgee
Re: 1974 cr125
« Reply #3 on: April 28, 2011, 07:53:06 am »
yes russ they do 31 mm to be exact
Re: 1974 cr125
« Reply #4 on: April 28, 2011, 01:13:05 pm »
they fit in the 30mm YZa125 tripples as well, which is what these ones are in currently.
Offline smed
Re: 1974 cr125
« Reply #5 on: April 28, 2011, 03:35:30 pm »
Believe it or not,the top clamp is identical to ct125/200 ag bike,the aggy has extra mounts cast in for the speedo,when i got my 74 cr125 the top clamp was broken, I matched them up to a set of the aggy ones at the local wreckers, I noticed on my original clamps where the lugs had been ground off,so thats what i done & they are still on there! The bottom clamp might also fit but they are steel not alloy,also the forks are very similar,of course i would assume the springing & damping would be different, both front & rear hubs look the same too, Now, no wise cracks about the elsie 125 just being a tarted up cockys bike :P
