Author Topic: Hindall Yamaha 360  (Read 2862 times)
Hindall Yamaha 360
« on: April 25, 2011, 07:42:09 pm »
After a three week full on thrash I managed to finish the Hindall 360 flat tracker in time to get her to the HBBB over the weekend. Unfortunately a minor ignition problem prevented any serious track action but I was glad the little bike got a lot of favourable comments.
All up the bike took three weeks and cost around $1000 to build (give or take a hundred or two.) Here's a rough breakdown of the parts used and the approximate costs.
Frame: A Hindall motocross frame originally made to house a 350 Kawasaki Bighorn, purchased 10 years ago for $100. I spent a week removing twenty years of tarnish and welding in new mounts to suit the Yamaha engine.
Forks: Early Yamaha DT forks kindly donated by Nathan S, fitted with Vintage Iron heavy duty TM250 Suzuki springs, new seals and 10wt ATF.
Wheels: front: 19" Akront rim/Carlilse 3:50 x 19 tyre and Yamaha MX250 hub I've owned for over 20 years. Rear: Yamaha MX250 fitted with Mitas 4:00 x 18 trials tyre.
Shocks:CR250 Elsinore.
Bodywork: Tank: Trackmaster with flame job as bought on eBay for $40. I had to repair two severe fork "rash" dents and blend/match the paint. Tail/seat. Supplied by Matcho Mick and fitted with the sear from the Trackmaster tail that didn't fit the frame.
Engine: Very early pistong port bottom end rebuilt with new 214 rod/bigend, Barnett Kevlar clutch and PVL ignition. The cylinder is an RT2 reed cylinder on original bore fitted with a NOS piston/rings, Boyesen reeds, ACK head, 34mm Mikuni, unknown manufacture downpipe and Supertrapp muffler.
Little stuff:Inter-Am solid alloy flat track bars, Chinese pitbike billet throttle, Magura/Yamaha levers, Donkey Dick grips, Alloy number plates, pit bike air filter, Circle Industries fork brace.
The bike is one half of a matching pair- 'the Hindall Sisters', the other bike with identical frame but set up for motocross and fitted with a DT1 piston port engine wasn't finished in time for HBBB. It'll debut at CD8.
This was an especially enjoyable build as it allowed me a bit of 'artistic' freedom to do it the way I wanted, using parts from my second hand stash. The bike will be a continuously evolving project with the next mod being finding a set of adjustable triple clamps to allow me to bring the rake in to 25-26  degrees. I could acheive the needed geometry by cutting and shutting the frame but I'm hesitant to cut such a rare frame at this stage. I'll also fit a piston port barrel if the bike is to be used in the pre '70 class. I'm also replacing the 20 year old Carlilse front tyre with a Dunlop K160 or Maxxis.
« Last Edit: April 25, 2011, 10:17:22 pm by firko »
Re: Hindall Yamaha 360
« Reply #1 on: April 25, 2011, 08:11:50 pm »
Nice one Mark , what is the head from regards Iainyz
« Reply #2 on: April 25, 2011, 08:50:07 pm »
Good one scrooge  ;D
Yeah, but how does it go; how does it handle ;D.
« Last Edit: April 26, 2011, 10:25:43 am by mx250 »
« Reply #3 on: April 25, 2011, 09:35:31 pm »
The head's a pretty rare ACK. I've also got one on the 250 in the other Hindall.
Yeah, but how does it go; how does it handle .
I lost a screw out of the PVL ignition so I couldn't get it to run long enough to answer both of those questions. If it handles equally as good as the other Hindalls it'll be fine and I'm sure it'll go alright. It's as light a 360 as any I've felt before so it's no old RT1 lump. I'm taking it to the Nepean practice day in a fortnight to sort out the bugs and to experiment with different settings.
« Last Edit: April 25, 2011, 09:43:05 pm by firko »
« Reply #4 on: April 25, 2011, 09:41:58 pm »
very nice firko, beautiful proportions, love the tank!
« Reply #5 on: April 26, 2011, 09:48:12 am »
Looked a treat Firko! ;) Great tank art work ;)  Shame the lack of one odd sized bloody 4mm screw put paid to some quality track time. Cheers Tim754
